[fdo-users] RE: [mapguide-users] Advanced WMS providerconfiguration
Greg Boone greg.boone at autodesk.com
Fri Apr 13 10:15:27 EDT 2007
I doubt my code sample would illustrate how MapGuide uses the
configuration document. My sample will only provide a programmatic
illustration on how to dynamically generate the configuration document.
Greg
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Tweedie
Sent: Friday, April 13, 2007 1:04 AM
To: Jason Birch
Cc: fdo-users at lists.osgeo.org; MapGuide Users Mail List
Subject: RE: [fdo-users] RE: [mapguide-users] Advanced WMS
ResourceContent? Still getting used to mapguide terminology :-)
I was thinking that if this ever is solved that it should really be on
the wiki. It certainly isnt a simple process.
Perhaps if you just use the NASA sample XML file Jason, let me know if
you have any luck? Once i have something working i can easily port it
back to my services
Maybe Greg's code might be handy?
Thanks for your help.
Chris
On Thu, 12 Apr 2007 20:31:48 -0700, "Jason Birch"
<Jason.Birch at nanaimo.ca> wrote:
> Hmm.  Maybe uploading the configuration document doesn't automatically
set
> up the relationship between the feature source and the config
document.
> What does the ResourceContent (not header) for your WMS source look
like
> after uploading the content?
> Jason
> ________________________________
> From: Chris Tweedie
> Subject: [fdo-users] RE: [mapguide-users] Advanced WMS provider
> configuration
> Hi Jason, thanks for the additional info.
> I'm still a little confused on the relationship between the config
file
> attached to the data connection and the mapguide layer. I used the
> multi-layer XML example to define multiple layers, however how do i
then
> create a new mapguide layer based on the custom commands? If i try to
> create a layer based off the connection, it simply queries the WMS
> featureserver again and gives me a list of the featuretypes as usual?
> <Layer name="srtm_mag">
>  <Style name="default"/>
> </Layer>
> <Layer name="global_mosaic">
>  <Style name="pseudo"/>
> </Layer>
> If i can finish this last step it certainly will solve my problems
> Chris
Chris Tweedie
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
