[mapguide-users] King Oracle FDO Provider Single select hights all
features
Joseph Doherty
jdoherty at Microdesk.com
Tue Apr 17 16:23:13 EDT 2007
I am using Mapguide Enterprise 2007 SP1, Mapguide Studio, Oracle
Enterprise Ed. 10.2.0.1.0 and the King Oracle FDO (0.6.4).
Oracle and Mapguide are on the same machine and using the regular Oracle
Client, not the Instant client.
In Mapguide Studio, I have a layer defined using a KingFDOClass based on
a view. When I view this layer in a Mapdefinition and select a single
line, all the lines are selected.
This behavior happens after applying SP1 to Mapguide. This behavior does
not happen when I use the base table.
The view has a primary key defined, below is additional info:
Below is the table "CMGENCLD" , the King FDO Class definition table
(showing only the columns with values)
FDO_UNIQUE_ID
FDO_ORA_OWNER
FDO_ORA_NAME
FDO_ORA_GEOMCOLUMN
FDO_SPATIALTABLE_OWNER
FDO_SPATIALTABLE_NAME
FDO_SPATIALTABLE_GEOMCOLUMN
FDO_CLASS_NAME
FDO_IDENTITY
1061
GUTAPP
V_UTWATPIP_BASE
GEOMETRY
GUTAPP
UTWATPIP
GEOMETRY
V_UTWATPIP_BASE_CLS
DATALINK
These are entries in the MDSYS.SDO_GEOM_METADATA_TABLE for the GUTAPP
user/schema
SDO_OWNER
SDO_TABLE_NAME
SDO_COLUMN_NAME
SDO_SRID
GUTAPP
UTWATPIP
GEOMETRY
41051
GUTAPP
V_UTWATPIP_BASE
GEOMETRY
41051
Any thoughts or insights would be appreciated.
Mahalo,
Joseph Doherty
Software Engineer
Oracle Certified Professional
Microdesk, Inc.
P: 781-419-8105
C: 781-820-1389
F: 781-890-5275
www.microdesk.com <http://www.microdesk.com>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070417/9672c1a7/attachment-0001.html
