[mapguide-users] King Oracle FDO Provider Single select hights allfeatures
Haris Kurtagic haris at sl-king.com
Sat Apr 21 16:09:51 EDT 2007
I have looked into this and I got same behavior.
What is happing is that MG layer created from class doesn't have
identity properties set.
If you select one feature it will be selected (just one in properties
window) but all will be rendered as selected (blue).
This means that provider is correctly running spatial filter to select
just one feature.
What I found in MapGuide is that if provider is returning just one FDO
Schema (KingOra ) instead of two FDO Schemas (KingOra and KingFdoClass )
it is working properly.
I have checked with Fdo2Fdo and both FDO classes, from base table and
view, look's exactly same except FDO schema name and still layer created
in MapGuide for one class has identity property set and not for another
class.
I am not 100% sure but because of this findings in this moment it looks
like issue with MapGuide (or Studio) not the provider.
Unfortunately I am traveling again and right now I don't' have time to
investigate it further.
My reply is coming little late because I was travelling and not able to
look at this before.
Haris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joseph
Doherty
Sent: 17. april 2007 22:23
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] King Oracle FDO Provider Single select hights
allfeatures
I am using Mapguide Enterprise 2007 SP1, Mapguide Studio, Oracle
Enterprise Ed. 10.2.0.1.0 and the King Oracle FDO (0.6.4).
Oracle and Mapguide are on the same machine and using the regular Oracle
Client, not the Instant client.
In Mapguide Studio, I have a layer defined using a KingFDOClass based on
a view. When I view this layer in a Mapdefinition and select a single
line, all the lines are selected.
This behavior happens after applying SP1 to Mapguide. This behavior does
not happen when I use the base table.
The view has a primary key defined, below is additional info:
Below is the table  "CMGENCLD" , the King FDO Class definition table
(showing only the columns with values)
FDO_UNIQUE_ID
FDO_ORA_OWNER
FDO_ORA_NAME
FDO_ORA_GEOMCOLUMN
FDO_SPATIALTABLE_OWNER
FDO_SPATIALTABLE_NAME
FDO_SPATIALTABLE_GEOMCOLUMN
FDO_CLASS_NAME
FDO_IDENTITY
1061
GUTAPP
V_UTWATPIP_BASE
GEOMETRY
GUTAPP
UTWATPIP
GEOMETRY
V_UTWATPIP_BASE_CLS
DATALINK
These are entries in the MDSYS.SDO_GEOM_METADATA_TABLE for the GUTAPP
user/schema
SDO_OWNER
SDO_TABLE_NAME
SDO_COLUMN_NAME
SDO_SRID
GUTAPP
UTWATPIP
GEOMETRY
41051
GUTAPP
V_UTWATPIP_BASE
GEOMETRY
41051
Any thoughts or insights would be appreciated.
Mahalo,
Joseph Doherty
Software Engineer
Oracle Certified Professional
Microdesk, Inc.
P: 781-419-8105
C: 781-820-1389
F: 781-890-5275
www.microdesk.com  <http://www.microdesk.com>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070421/64215b18/attachment-0001.html
