[mapguide-users] Using KmlService
Adrià
amptarraco at hotmail.com
Wed Apr 18 05:12:18 EDT 2007
I find exactly the same behaviour.
Does anyone know if the KmlService is available through the web extensions
in the current version of MapGuide?
Jim O wrote:
> Has anyone been able to use the new KML service? I am able to get a
> response if I use the browser and enter:
> http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GetMapKml&VERSION=1.0.0&MAPDEFINITION=Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition
> I am also able to get a response if I go to the mapagent at
> http://localhost:8008/mapguide/mapagent/ and
> click the Kml under Service API, click GetMapKml and then accept the
> defaults for Sheboygan in the
> Map Definition box.
> However, I'm not able to get a KmlService by typing:
> $kmlService = $siteConnection->CreateService(MgServiceType::KmlService);
> When I look inside mapviewerphp\constants.php, I see that KmlService is
> type 6. But both the above and
> $kmlService = $siteConnection->CreateService(6);
> produce the error
> Fatal error: The class MgService (or one of its derived classes) has no
> runtime type id in C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\...
> Any suggestions?
> Thanks
View this message in context: http://www.nabble.com/Using-KmlService-tf3125455s16610.html#a10054964
