[mapguide-users] Using KmlService
Kori Maleski
Kori.Maleski at websoftdev.com
Wed Apr 18 13:37:47 EDT 2007
The KML Service functionality is not exposed with the API.
In order to utilize it you will have to make actual Http Requests.
Mr. Birch has more details here on the requests here:
http://www.jasonbirch.com/nodes/2007/01/22/56/kml-support-in-mapguide-110/
Others may have more input...
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
kori.maleski at websoftdev.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Adrià
Sent: Wednesday, April 18, 2007 2:12 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Using KmlService
I find exactly the same behaviour.
Does anyone know if the KmlService is available through the web extensions
in the current version of MapGuide?
Jim O wrote:
> Has anyone been able to use the new KML service? I am able to get a
> response if I use the browser and enter:
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GetMapKml&VE
RSION=1.0.0&MAPDEFINITION=Library://Samples/Sheboygan/Maps/Sheboygan.MapDefi
nition
> I am also able to get a response if I go to the mapagent at
> http://localhost:8008/mapguide/mapagent/ and
> click the Kml under Service API, click GetMapKml and then accept the
> defaults for Sheboygan in the
> Map Definition box.
> However, I'm not able to get a KmlService by typing:
> $kmlService = $siteConnection->CreateService(MgServiceType::KmlService);
> When I look inside mapviewerphp\constants.php, I see that KmlService is
> type 6. But both the above and
> $kmlService = $siteConnection->CreateService(6);
> produce the error
> Fatal error: The class MgService (or one of its derived classes) has no
> runtime type id in C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\...
> Any suggestions?
> Thanks
View this message in context:
http://www.nabble.com/Using-KmlService-tf3125455s16610.html#a10054964
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
