[mapguide-users] Can't GenerateFilter on newly added features
Bruno Scott bscott at geomapgis.com
Mon Apr 23 11:25:00 EDT 2007
I have found my problem.
2 things
  1) Identation of the xml layer definition, if we do not respect some form
of identation, it produces weird things
      // Create a line rule to stylize the lines
      string layerDefinition = "";
      layerDefinition += "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
      layerDefinition += "<LayerDefinition version=\"1.0.0\" ...>";
      layerDefinition += "    <VectorLayerDefinition>\n";
      layerDefinition += "      <ResourceId>" + featureSourceName +
"</ResourceId>\n";
      layerDefinition += "      <FeatureName>SHP_Schema:" + layerName +
"</FeatureName>\n";
<FeatureNameType>FeatureClass</FeatureNameType>\n";
      layerDefinition += "      <Geometry>" + geometryPropertyName +
"</Geometry>\n";
      layerDefinition += "      <VectorScaleRange>\n";
      layerDefinition += "        <MinScale>0</MinScale>\n";
      layerDefinition += "        <MaxScale>1000000000000</MaxScale>\n";
      layerDefinition += "        <LineTypeStyle>\n";
      layerDefinition += "          <LineRule>\n";
      layerDefinition += "            <LegendLabel>Lines
Rule</LegendLabel>\n";
      layerDefinition += "            <Filter></Filter>\n";
      layerDefinition += "            <LineSymbolization2D>\n";
      layerDefinition += "              <LineStyle>Solid</LineStyle>\n";
      layerDefinition += "              <Thickness>2</Thickness>\n";
      layerDefinition += "              <Color>FFFF00FF</Color>\n";
      layerDefinition += "              <Unit>Points</Unit>\n";
      layerDefinition += "            </LineSymbolization2D>\n";
      layerDefinition += "          </LineRule>\n";
      layerDefinition += "        </LineTypeStyle>\n";
      layerDefinition += "      </VectorScaleRange>\n";
      layerDefinition += "    </VectorLayerDefinition>\n";
      layerDefinition += "</LayerDefinition>\n";
 2)
  I was using MgBaseLayer class instead of MgLayer.
  When doing this, everithing seems to works fine except that the
generatefilter does not work
Bruno Scott wrote:
> I've build a small redlining application following the DevGuide samples.
> So i create a new FeatureDefinition
> then i insert my features in it
> then i create a new layer and add it to the map.
> This thing works pretty well
> Since i have set my layer as selectable i can select any of my redlines
> The thing i want to implement is the possibility to delete a single
> redline feature.
> So i get the selectionXML from the viewer and i pass it to an server page
> to delete it.
> when i do
> 'string filter = selection.GenerateFilter(layer, layerClassName);'
> my filter is allways empty...
> I have suspected a wrong sdf...
> So i created manually a new layer in studio and i have added my sdf
> On this new layer, i have no problem generating the layer...
> This meens that my sdf is OK.
> Anyone have an idea on what's happening?
> Thanks
> Bruno
View this message in context: http://www.nabble.com/Can%27t-GenerateFilter-on-newly-added-features-tf3553044s16610.html#a10142568
