[mapguide-users] Unable to start MGServer on a VPS
Trevor Wekel trevor.wekel at autodesk.com
Mon Apr 23 12:14:02 EDT 2007
What VPS technology are you using?  I have had some success using
Virtuozzo.  MapGuide will attempt to open ports 2800, 2801, and 2802 on
all interfaces.  Generally even if a firewall is blocking traffic to
these ports, MapGuide will still be able to listen on the same  ports.
It will simply never receive any connections.  If was to hazard a guess,
I would suspect that another process has already bound to these ports.
If you run 'netstat -ano' from the command line and you see a line like
this
TCP    0.0.0.0:2801           0.0.0.0:0              LISTENING
4812
Then that means process 4812 has already bound port 2801.  You should be
able to use Task Manager to track down which process has the port.
-----Original Message-----
From: Nimrod Cnaan [mailto:nimcnaan at Hotmail.com]
Sent: Saturday, April 21, 2007 3:27 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Unable to start MGServer on a VPS
Mgserver.exe service starts and then stops, with an error massage
"Server starting . . . "
"Proj4 coordinate system library"
"Port 2801 is not availibale pleas try using different port  . . "
*	My application is Hosted on a VPS (Virtual Private Server) with
Windows
2003 server OS
*	Ports 2800-2801 have been opened (TCP In&Out bound) at the
public Firewall
*	I'm using MGOS 1.1.0 environment
I'm a beet confused as for weather I'm doing something wrong or should I
use a dedicated server instead of the VPS.
View this message in context:
http://www.nabble.com/Unable-to-start-MGServer-on-a-VPS-tf3624551s16610.
html#a10121237
