[mapguide-users] Feature Joins Failing in MapGuide Open Source1.2.0
James Card James.Card at calcad.com
Fri Apr 27 17:11:14 EDT 2007
On Fri, 27 Apr 2007 13:29:37 -0700, Dave Wilson <dave.wilson at autodesk.com>
wrote:
> I would expect an error if it wasn't, but your MySQL must be 5.022 or
> later because of an FDO requirement.
It is MySQL 5.0.24.
> The SQLServer should work. Could you try a connection string to
> SQLServer instead?
Using a connection string rather than a DSN makes no difference, for
either the SQL_Server or the MySQL connection.
James Card
California CAD Solutions, Inc.
209 578-5580
