[mapguide-users] Feature Joins Failing in MapGuide Open Source1.2.0
Dave Wilson dave.wilson at autodesk.com
Fri Apr 27 16:29:37 EDT 2007
I would expect an error if it wasn't, but your MySQL must be 5.022 or
later because of an FDO requirement.
The SQLServer should work. Could you try a connection string to
SQLServer instead?
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of James Card
Sent: Friday, April 27, 2007 2:14 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Feature Joins Failing in MapGuide Open
Source1.2.0
On Fri, 27 Apr 2007 12:10:32 -0700, Dave Wilson
<dave.wilson at autodesk.com>
wrote:
> Can you provide more details? What database type are you trying to
> join to?
One dataset connects to SQL-Server via ODBC; the other connects to
MySQL, again via ODBC. The database server is a separate machine on the
same network. Other ODBC-based tools on the running on MapGuide server
connect using the same system DSNs with no problem.
> Card
> Sent: Friday, April 27, 2007 1:06 PM
> Subject: [mapguide-users] Feature Joins Failing in MapGuide Open
> Source 1.2.0
> After successfuly defining a join for a FeatureSource the new
> FeatureClass doesn't appear when creating a new LayerDefinition, only
> the default FeatureClass is available.
James Card
California CAD Solutions, Inc.
209 578-5580
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
