[mapguide-users] Feature Joins Failing in MapGuide Open Source 1.2.0
James Card James.Card at calcad.com
Fri Apr 27 16:13:47 EDT 2007
On Fri, 27 Apr 2007 12:10:32 -0700, Dave Wilson <dave.wilson at autodesk.com>
wrote:
> Can you provide more details? What database type are you trying to join
> to?
One dataset connects to SQL-Server via ODBC; the other connects to MySQL,
again via ODBC. The database server is a separate machine on the same
network. Other ODBC-based tools on the running on MapGuide server connect
using the same system DSNs with no problem.
> -----Original Message-----
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of James Card
> Sent: Friday, April 27, 2007 1:06 PM
> Subject: [mapguide-users] Feature Joins Failing in MapGuide Open Source
> 1.2.0
> After successfuly defining a join for a FeatureSource the new
> FeatureClass doesn't appear when creating a new LayerDefinition, only
> the default FeatureClass is available.
James Card
California CAD Solutions, Inc.
209 578-5580
