[mapguide-users] Feature Joins Failing in MapGuide Open Source
1.2.0
Dave Wilson
dave.wilson at autodesk.com
Fri Apr 27 15:10:32 EDT 2007
Can you provide more details? What database type are you trying to join
to?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of James Card
Sent: Friday, April 27, 2007 1:06 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] Feature Joins Failing in MapGuide Open Source
1.2.0
We had given up on using feature joins to ODBC tables because
performance with previous versions was too slow. We resorted to placing
all the required data into the SDF files.
The 1.2.0 beta is supposed to have improvements in this area so we're
trying again. However, after successfuly defining a join for a
FeatureSource the new FeatureClass doesn't appear when creating a new
LayerDefinition, only the default FeatureClass is available.
I've reread the documentation and reviewed messages on this list
relating to joins, but still can't determine what's causing the problem.
Others on this list aren't complaining of joins being broken so it is
probably a local issue. Has anyone else encountered this problem? and
hopefully can tell me what I've done wrong?
James Card
California CAD Solutions, Inc.
209 578-5580
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
