[mapguide-users] .MPG Package
Kenneth ks at geograf.dk
Mon Apr 30 06:09:52 EDT 2007
feras wrote:
> HI..
> I 'am new to mapguide So Can anybody help me to make .Mpg package in a list
> of instruction. because i got tired of this.
> Thanks.
Open http://localhost:8008/mapguide/mapadnin/login.php
Type username/password (default is Administrator/admin) and click "Log in".
Click on "Manage Packages"
On the left side of the screen, type the path to the top most folder, eg:
Entire server: Library://
Only Redding: Library://Redding
Type something meaningfull in the box "Resulting package name", eg: "my
package.mpg".
Click the "Make button".
The package will be placed in the Package directory (usually C:\Program
Files\MapGuideOpenSource\Server\Packages).
If you use Linux, or have changed the default directory, Click "Manage
Packages" on the right, and "Configure Packages Directory" on the right.
You can now see what the package directory is configured to be.
All packages created by the MapGuide Server will be placed in this folder.
To load a package, place it in this folder, login to the MapGuide Server
Admin as described above.
Click "Manage packages" on the right, select the package on the list
(bottom, left).
Then click "Load Package".
Note that only files with the "mgp" file extension will show up in the list.
Regards, Kenneth, GEOGRAF A/S
