[mapguide-users] Trouble making web layout work from session repository
gom gord.mckenzie at canam.com
Thu Aug 2 16:38:50 EDT 2007
I am trying to load a modified map and web layout from the session
repository. I have had success up to the final step.
I get the mapdefintion from the repository
I modify the XML to change the extents and save it to the session repository
I get the weblayout from the repository
I modify the XML to change the mapdefinition and save it to the session
repository
When I try to use the modified layout I get the following error.
Argument is null.
Argument is null. Exception occurred in method MgWebLayout.ParsePrintCommand
at line 880 in file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\web\src\webapp\WebLayout.cpp
If I just get the webLayout from the repositry and stuff it into the session
repository I can then make that my current layout and it works great.  I
call one function that changes the ResourceID under the Map node of the XML
and it generates the above error.  Comparing the weblayout XML before and
after I change the ResourceID seems to indicate that the files are identical
except for the changed mapdefintion.  Any ideas what I might be doing wrong?
Thanks
View this message in context: http://www.nabble.com/Trouble-making-web-layout-work-from-session-repository-tf4208650s16610.html#a11972354
