[mapguide-users] ODBC Points Performance
Ismael Cams mapguide2007 at gmail.com
Mon Aug 6 04:38:14 EDT 2007
If you can avoid using SQL Server I would advice to not use it. It is really
very slow (also note to not use the Native Client driver as this is not
working -> tables are not showed).
Connection with Access is faster but I encountered some unstabilities with
it. I did not investigate it further but I guess it is a problem with too
many connections towards the Access database.
I have finally transported all the data into an SDF which is working much
much faster.
Jon Rizzo wrote:
> I was told specifically the oposite - that ODBC performance of SQL Server
> is slower than all other ODBC providers, including Access.  I have not
> verified this claim, but I can tell you that selection is particularly
> slow with points coming from SQL Server.  I have also had a performance
> problem selecting polygons if they are joined with data coming from SQL
> Server.  I don't know enough about the problem to know if this is a
> MapGuide or a Microsoft issue but selection on my site is terribly slow
> because of this.
> Jon
> None None-9 wrote:
>> Is anyone using ODBC to Access to display point layers on a production
>> server? Are there known issues with selecting and overall speed? I am
>> assuming yes, and if so has anyone used MS SQL for the same thing and
>> notices an improvment with the Enterprise FDO?
>> The Rock
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/ODBC-Points-Performance-tf4201424s16610.html#a12012749
