[mapguide-users] ODBC Points Performance
Jon Rizzo jrizzo at Langan.com
Mon Aug 6 08:10:57 EDT 2007
Strange, we an ArcIMS site pulling points & other data out of a SQL Server
database without a problem.  Moving the data to SDF is not a desireable
solution, since we have other systems in place that rely on the same data
being available to ODBC/SQL.  Duplicating data is certainly an option, it
just defeats the point of having an enterprise database in the first place.
Ismael Cams wrote:
> If you can avoid using SQL Server I would advice to not use it. It is
> really very slow (also note to not use the Native Client driver as this is
> not working -> tables are not showed).
> Connection with Access is faster but I encountered some unstabilities with
> it. I did not investigate it further but I guess it is a problem with too
> many connections towards the Access database.
> I have finally transported all the data into an SDF which is working much
> much faster.
> Jon Rizzo wrote:
>> I was told specifically the oposite - that ODBC performance of SQL Server
>> is slower than all other ODBC providers, including Access.  I have not
>> verified this claim, but I can tell you that selection is particularly
>> slow with points coming from SQL Server.  I have also had a performance
>> problem selecting polygons if they are joined with data coming from SQL
>> Server.  I don't know enough about the problem to know if this is a
>> MapGuide or a Microsoft issue but selection on my site is terribly slow
>> because of this.
>> Jon
>> None None-9 wrote:
>>> Is anyone using ODBC to Access to display point layers on a production
>>> server? Are there known issues with selecting and overall speed? I am
>>> assuming yes, and if so has anyone used MS SQL for the same thing and
>>> notices an improvment with the Enterprise FDO?
>>> The Rock
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/ODBC-Points-Performance-tf4201424s16610.html#a12015144
