[mapguide-users] [Ajax viewer Bug] "offset" in displayed image
David Hequet
david.hequet at free.fr
Wed Aug 8 10:16:54 EDT 2007
look at my modification, it seems to work fine with ResizeMapSpace(); at then
end of load
Ismael Cams wrote:
> Hello David,
> this seems to be a problem similar I reported about a week ago
> (http://www.nabble.com/forum/ViewPost.jtp?post=11809953&framed=y&skin=16610)
> When you leave the properties pane enabled the offset is correct.
> I did not post it as a bug until now.
> Kind regards,
> Ismaël
> David Hequet wrote:
>> Hi,
>> There is a bug in displaying map image in the Ajax Viewer:
>> Look at this screenshot, the image is cut on the top.
>> http://www.nabble.com/file/p12050259/MGVIEWER_OFFSETERROR.jpg
>> this "offset" is really anoying:
>> - the image is not well displayed
>> - but the mouse coordinates are catched without the offset: it cause bad
>> selection : you click a polygone, it take the polygone 10px lower. Sames
>> for tooltips.
>> - This bug appears only when the property pane is not showed on the
>> WebLayout and the browser size is higher than (around) 500px or 600px
>> - It disapears when you resize the window.
>> - I tried on firefox and IE 6
>> I modified the ajaxmappane.tmpl by Adding a call to ResizeMapSpace() in
>> the delayedInit() Method like this:
>> GetPropertyCtrl().SetProperties(0);
>> ResizeMapSpace();
>> mapInit = true;
>> parent.OnMapLoaded();
>> It's not very good but there is no "offset" bug after this.
>> David
View this message in context: http://www.nabble.com/-Ajax-viewer-Bug--%22offset%22-in-displayed-image-tf4235307s16610.html#a12054144
