[mapguide-users] Where to backup files?
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Aug 9 07:32:46 EDT 2007
If you log into the "Site Administrator", there is an menu called
"Manage Pacakges".
This menu can be used to create a copy of the repositories.
You can use this method, if you have already divided the server into
folders.
You may then choose to create a package for only a subfolder.
The created package will contain all data that is present in the repository.
That means datafiles, such as SDF, layers, maps, weblayouts, etc,
but not external data such as databases, unmanaged SDF/SHP etc.
You can load the package at any time, and it will overwrite any
files/folders.
Regards, Kenneth, GEOGRAF A/S
jamesdudden skrev:
> Hi all
> I would like some advice on backing up files please. I have created a
> weblayout with all the various layers in Studio. I know that the data goes
> into the repositries folder but where is the actual layout stored?
> I would like to backup individual projects rather than backing up the whiole
> of the mapguide folder.
> Does anybody have any advice?
> Kind Regards
> James Dudden
> www.software-matters.co.uk
