[mapguide-users] MG2007 and PHP as ISAPI on IIS5.1
akramany
asm at cad-gis.com
Thu Aug 9 10:59:07 EDT 2007
Hi Rahul ,
you can solve you problem by these steps :
* If you using MapGuide Server you should install it with windows 2003
server without SP2
* If you use ASP.NET with IIS in same machine you should do this steps
1. Click Start, click Run, type cmd in the Open box, and then click OK.
2. Switch to the Drive:\Windows\Microsoft.Net\Framework\v1.1.4322 folder. In
this folder, Drive is the drive where Windows is installed. To do this, type
the following line at the command prompt, and then press ENTER:
cd Drive:\windows\microsoft.net\framework\v1.1.4322
3. Add the appropriate permissions to the Network Service group for the
Temporary ASP.NET Files folder. To do this, type the following line, and
then press ENTER:
aspnet_regiis -ir
Note For more information about the difference between the -ir command-line
option and the -i command-line option, visit the following Microsoft Web
site:
http://msdn2.microsoft.com/en-us/library/k6h9cz8h(vs.71).aspx
(http://msdn2.microsoft.com/en-us/library/k6h9cz8h(vs.71).aspx)
4. Type exit, and then press ENTER to quit the command prompt.
* in web.config make <authentication mode="None"/>
Rahul-2 wrote:
> Hi All,
> I am running Windows XP with IIS 5.1. Now I am currently testing with
> installed MG Server(on Machine -A) and MG Web Server Extensions using
> PHP, a custom IIS config and a typical setup(on Machine -B).When testing
> the Site Admin use to give the failed logging error using Administrator
> and admin password and the MapAgent and Server
> Extensions throw up this message:
> Cannot establish connection.
> Cannot establish connection. Exception occurred in method
> MgServerConnection.Open at line 95 in file .\Services\ServerConnection.cpp
> I installed MG on Windows using the set up guide and step by step method
> for Php and IIS Configuration and checked all of the criteria including
> directory structure and the viewer properties etc.Kindly if somebody can
> suggest me where i am missing the bus i will be really thankfull.
> Cheers
> Max
> Luggage? GPS? Comic books?
> Check out fitting gifts for grads at Yahoo! Search.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/How-Can-I-load-SDF-tf4151735s16610.html#a12073989
