[mapguide-users] Re: Webstudio upload feature source?
kuba_debek
j.debek at gmail.com
Sat Aug 11 17:26:30 EDT 2007
Hello TW,
Now I have the same problem as you. I can not create layer from feature
source. (blank list geometry and feature class). Can you tell me how you
solved this problem?
Kuba
TW wrote:
> Zak,
> Yes, the sdf file I create will upload through webstudio, as long as it is
> not to large. I noticed that file sizes that are several MB's will
> generate an error and fail to load.
> I also noticed if I take a sdf from the sheboygan set and modify it (in
> map 2007) with the sdf still in the library repository, webstudio will
> still allow me to create functioning layers with it.
> However, if I take a sheboygan sdf "islands" and modify the file in Map3d
> and re-upload the data back with webstudio, the sdf will be in the
> repository but will not allow the creation of a functioning layer.
> In the layer menu I can select the feature datasource, but cannot specify
> the geometry field or the Feature geometry in the Feature data selection.
> I am still trying different things so that I may have more specific
> answers and descriptions as to the problems.
> I also noticed I cannot change the color selection for layers in the style
> menu. I can open the style area and select the fill and line style but
> cannot change the color using the button on the left.
> I hope this makes sense
> Tim
> Zak James wrote:
>> Tim,
>> During development, we tested the upload facility only with the
>> default apache web server so IIS may be involved in your problems. Can
>> you verify that the sdf file is present in the repository after
>> upload?
>> zak
>> On 11/1/06, METRO3 <twiebe at cityofwinkler.ca> wrote:
>>> It appears now that I can upload a datasource. I had to reinstall the
>>> server
>>> and extensions 1.0.2.
>>> However, even though I can upload the data, when I try to create a
>>> layer
>>> from the uploaded sdf data. I am unable to select the featureclass or
>>> geometry to setup the layer.
>>> Is there criteria for creating sdf3? Should I consider shapefiles?
>>> I am creating a my sdf3 in Map 2007 my projection is NAD83 UTM.
>>> Using IIS5 for the server.
>>> THanks
>>> Tim
>>> Paul Spencer-2 wrote:
>>> > Tim,
>>> > there were some problems with the original implementation of the
>>> > upload facility in webstudio. These were fixed recently in the trunk
>>> > but I don't know if those fixes made it into 1.0.2 release.
>>> > Can you let us know a bit about your configuration (server, web
>>> > server, version) and any error messages you are getting?
>>> > Cheers
>>> > Paul
>>> > On 31-Oct-06, at 3:51 PM, Tim Wiebe wrote:
>>> >> I am new to working with mgos, but can someone tell me why I can't
>>> >> upload my own sdf3 or shp through webstudio?
>>> >> Am I missing something obvious?
>>> >> Thanks
>>> >> Tim
>>> > |Paul Spencer pspencer at dmsolutions.ca |
>>> > |Chief Technology Officer |
>>> > |DM Solutions Group Inc http://www.dmsolutions.ca/ |
>>> > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> > For additional commands, e-mail: users-help at mapguide.osgeo.org
>>> View this message in context:
>>> http://www.nabble.com/Webstudio-upload-feature-source--tf2548311.html#a7116223
>>> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
>> Zak James
>> Applications and Software Development
>> DM Solutions Group Inc.
View this message in context: http://www.nabble.com/Webstudio-upload-feature-source--tf2548311s16610.html#a12109192
