[mapguide-users] AJAX Viewer: Selecting points from Oracle (King Oracle Provider) (MGO 1.2)
Joel Carranza jec at gatekeeper.com
Mon Aug 13 20:21:01 EDT 2007
Selection won't work for any layer that doesn't have a primary key defined.
If the layer is based on a view,  the underlying primary key may need to be
specified explicitly.
Joel
Gatekeeper Systems
Manuel Ferreira-2 wrote:
> Hi all,
> is it possible to select points from an Oracle (King Oracle Provider)
> datasource in the AJAX Viewer from MGO 1.2? I used MapGuide Studio to
> create the layer and make it selectable. The Layer is shown, but I am
> not able to select a point. Selecting polygons from an Oracle datasource
> works.
> Thank You!
> Manuel
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/AJAX-Viewer%3A-Selecting-points-from-Oracle-%28King-Oracle-Provider%29-%28MGO-1.2%29-tf4260161s16610.html#a12136686
