[mapguide-users] Connect MGOS to Postgis database
Intengu Technologies sindile.bidla at gmail.com
Thu Aug 16 13:43:33 EDT 2007
I have done that C:\Program Files\PostgreSQL\8.2\bin;
PostGIS is on the same machine as MapGuide (using it as a test machine)
But I still cannot see anything on Web Studio
Thanks for the help so far
On 16/08/07, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
>  >>>Do you have the PostgreSQL/bin directory in the system (not user) path
> on the server?
> > Do not quite follow this how can I check this
> The PostGIS provider requires access to the PostgreSQL/bin folder (the
> libpq.dll file, and its dependencies)  If you don't have PostGIS installed
> on the same machine as the MapGuide server (which would make sense), then
> just copy the entire directory from your PostGIS installation onto the
> MapGuide server.  Then add it to the system path.
> You can do this by right clicking on My Computer, then going to
> Properties->Advanced->Environment Variables.  Under the "System Variables"
> area, there should be a PATH variable.  Edit this variable, adding the
> complete path to the local copy of the bin directory at the start of this
> variable, followed by a semicolon.
> Jason
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Sindile Bidla
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070816/b66e032a/attachment.html
