[mapguide-users] Touches
Mbonnet
mbonnet at adelior.gfi.fr
Mon Aug 20 05:44:02 EDT 2007
ok thanks a lot.
Kenneth, GEOGRAF A/S wrote:
> If you look at the GetCapabilities of the SDF provider, you will see
> that it supports the following spatial operators:
> Contains
> Disjoint
> Intersects
> Within
> Inside
> EnvelopeIntersects
> So, there is no support for "Touches" with the SDF provider. Can you use
> the "Intersects" instead?
> Regads, Kenneth, GEOGRAF A/S
> Mbonnet skrev:
>> Hi,
>> i want to use the spatial query Touches but, i have this Error :
>> Operation
>> spatiale FDO non prise en charge. so it says that i can't use this query,
>> is
>> it a known issue ?
>> my code :
>> queryOptions2.SetSpatialFilter(layerObj.GetFeatureGeometryName(),geometry,MgFeatureSpatialOperations.Touches);
>> i use mapguide open source 1.2 rc2 with SDF files
>> thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Touches-tf4297593s16610.html#a12232868
