[mapguide-users] Fusion Map Problem
Paul Spencer pagameba at gmail.com
Thu Aug 30 17:11:03 EDT 2007
Hi Scott,
It sounds like it might be caching the XmlHttpRequest to load the web
layout.  Have you tried it in FireFox?  Do you have FireBug
installed?  If yes, you can look at the actual requests as the load
the web layout from the server and perhaps get a clue as to what is
going on.  If you have a public url that I can access, I might be
able to debug further.  Feel free to email me directly if you don't
want the URL on the list.
Cheers
Paul
On 30-Aug-07, at 8:24 AM, Scott Wilson wrote:
> All,
> I have the fusion Sheboygan demo working fine. The problem is when
> I try to display a different a map.
> I have successfully uploaded a new map and tested it in web studio.
> I then edit the WebLayout.xml file within the simple fusion sample
> to reflect the new map:
> <CommandSet>
> <Command xsi:type="MapCommandType">
> <Name>Map</Name>
> <Action>MGMap</Action>
> <ResourceId>Library://test/test.MapDefinition</ResourceId>
> </Command>
> I save the WebLayout.xml and have tried restarting the mapguide
> service or rebooting. When I reload the simple fusion demo the map
> still shows Sheboygan.
> I am using Release 1.2.0 RC2 and the Fusion Preview 1.0
> Am I missing anything?
> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
