[mapguide-users] Fusion Map Problem
Scott Wilson
gswilson at gmail.com
Fri Aug 31 18:11:09 EDT 2007
Hi Paul,
Thank you for your insight and suggestion.
Turned out to be a browser caching issue and FDO problem.
Firebug is a great plug-in, thanks for the heads up!
On 8/30/07, Paul Spencer <pagameba at gmail.com> wrote:
> Hi Scott,
> It sounds like it might be caching the XmlHttpRequest to load the web
> layout. Have you tried it in FireFox? Do you have FireBug
> installed? If yes, you can look at the actual requests as the load
> the web layout from the server and perhaps get a clue as to what is
> going on. If you have a public url that I can access, I might be
> able to debug further. Feel free to email me directly if you don't
> want the URL on the list.
> Cheers
> Paul
> On 30-Aug-07, at 8:24 AM, Scott Wilson wrote:
> > All,
> > I have the fusion Sheboygan demo working fine. The problem is when
> > I try to display a different a map.
> > I have successfully uploaded a new map and tested it in web studio.
> > I then edit the WebLayout.xml file within the simple fusion sample
> > to reflect the new map:
> > <CommandSet>
> > <Command xsi:type="MapCommandType">
> > <Name>Map</Name>
> > <Action>MGMap</Action>
> > <ResourceId>Library://test/test.MapDefinition</ResourceId>
> > </Command>
> > I save the WebLayout.xml and have tried restarting the mapguide
> > service or rebooting. When I reload the simple fusion demo the map
> > still shows Sheboygan.
> > I am using Release 1.2.0 RC2 and the Fusion Preview 1.0
> > Am I missing anything?
> > Thanks
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070831/b4d7ed88/attachment.html
