[mapguide-users] Fusion Map Problem
Paul Spencer pagameba at gmail.com
Fri Aug 31 19:51:49 EDT 2007
Hi Scott,
was the problem purely a browser caching problem?  I have tried to
set up the ajax requests to be not cached by the browser regardless
of the client configuration so I am interested to know if it works or
not (I typically run my browsers with caching turned off so it is
hard for me to tell sometimes if this type of thing has stopped
working or not)
Cheers
Paul
On 31-Aug-07, at 6:11 PM, Scott Wilson wrote:
> Hi Paul,
> Thank you for your insight and suggestion.
> Turned out to be a browser caching issue and FDO problem.
> Firebug is a great plug-in, thanks for the heads up!
> On 8/30/07, Paul Spencer <pagameba at gmail.com> wrote: Hi Scott,
> It sounds like it might be caching the XmlHttpRequest to load the web
> layout.  Have you tried it in FireFox?  Do you have FireBug
> installed?  If yes, you can look at the actual requests as the load
> the web layout from the server and perhaps get a clue as to what is
> going on.  If you have a public url that I can access, I might be
> able to debug further.  Feel free to email me directly if you don't
> want the URL on the list.
> Cheers
> Paul
> On 30-Aug-07, at 8:24 AM, Scott Wilson wrote:
> > All,
> > I have the fusion Sheboygan demo working fine. The problem is when
> > I try to display a different a map.
> > I have successfully uploaded a new map and tested it in web studio.
> > I then edit the WebLayout.xml file within the simple fusion sample
> > to reflect the new map:
> > <CommandSet>
> > <Command xsi:type="MapCommandType">
> > <Name>Map</Name>
> > <Action>MGMap</Action>
> > <ResourceId>Library://test/test.MapDefinition</ResourceId>
> > </Command>
> > I save the WebLayout.xml and have tried restarting the mapguide
> > service or rebooting. When I reload the simple fusion demo the map
> > still shows Sheboygan.
> > I am using Release 1.2.0 RC2 and the Fusion Preview 1.0
> > Am I missing anything?
> > Thanks
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         |
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
