[mapguide-users] Why Nobody answers me? Fw: Really Need Help with MapGuide Studio and MGOS
Kenneth, GEOGRAF A/S ks at geograf.dk
Sun Dec 2 17:26:21 EST 2007
It is a good rule of thumb, to not have more than two questions in an email.
First reason is that usually someone can answer a few questions, but not
all, and might not respond.
Secondly, it takes time to answer an email, and if there are many
questions, it takes a lot of time.
1. You need an updated Dll for MapGuide Studio. It is avalible on the
website.
You must replace the one in the Studio folder, with the one from the
website.
http://mapguide.osgeo.org/download/relatedlinks
2. Please specify what goes wrong where.
3. MapGuide Studio is built for MapGuide Enterprise.
MapGuide Enterprise uses a different raster provider.
I belive someone already pointed you to the Gdal notes.
4. Try looking through the log files, perhaps they give a clue:
C:\Program Files\MapGuideOpenSource\Server\Logs
5. It sounds as if there is a problem with your charater set.
Try naming the resouce with english charaters only, and see if the
problem goes away.
Hope this helps you in the right direction.
Regards, Kenneth, GEOGRAF A/S
Saka Royban skrev:
> ----- Forwarded Message ----
> From: Saka Royban <srph124 at yahoo.com>
> To: MapGuide <mapguide-users at lists.osgeo.org>
> Sent: Sunday, November 25, 2007 8:45:10 PM
> Subject: Really Need Help with MapGuide Studio and MGOS
> Hi all.
> I've encountered some problems using MapGuide Studio 2007 Preview with
> MGOS:
> 1. It sounds MGS doesn't work with MGOS 1.2RC2 because it shows the
> message ' MapGuide Studio is incompatible with this version of Site
> Server'. Am i right? (although i've downloaded that dll and install it)
> Installing MGOS 1.1, i had these problems:
> 2. I cannot load dwg files to MGS. I don't know why but according to
> its Getting Started i had to be able to do this.
> 3. When i wanna load Raster files to server it shows the message "
> Server does not support requested Provider: Autodesk.raster
> 4. I established an Access DB connection, after saving it and testing
> connection it returned some errors (error 599)
> 5. I wanted to style one of layers but i wasn't able to view that
> layer receiving this error "XML page cannot be displayed. A name was
> started with an invalid character. Error processing resource"
> I appreciate any help because i'm a newbie to MG
> THX a lot
> Never miss a thing. Make Yahoo your homepage.
> <http://us.rd.yahoo.com/evt=51438/*http://www.yahoo.com/r/hs>
> Get easy, one-click access to your favorites. Make Yahoo! your
> homepage. <http://us.rd.yahoo.com/evt=51443/*http://www.yahoo.com/r/hs>
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071202/455d16c1/attachment.html
