[mapguide-users] Why Nobody answers me? Fw: Really Need Help with MapGuide Studio and MGOS
ori gudes ori at sinapistech.com
Mon Dec 3 09:20:41 EST 2007
Dear Saka Royban
1)I have the impression you have some general Installation problem, what I
would recommend you to do is that. First, remove the MapGuide application.
Then reinstall every thing from scratch (do you install in the .NET
configuration?). After you are finishing the installation process, please
check the document I uploaded that called (Necessary Steps After Installing
MapGuide Open Source). Please verify you do all the checks mentioned there
!!. After that go to the document called:
(InstallConfigureMgEnterpriseOnWindows.pdf) and do the diagnostics mentioned
in pages 35-36. You also need to install a patch file called:
MG7_STUDIO_SP1a.exe
This will enable the MapGuide Studio to connect to the MGOS Server.
If every thing Is fine, now you can start working in MapGuide Open Source.
2) Probably it will solve section 2 as well..
3) In Order to upload raster, See the attached file called: raster.doc, that
explains how to upload raster files to MGOS.
4) Probably it will solve section 4 as well..
5) Probably it will solve section 5 as well. please verify you pass
successfully the Diagnostics stage.
Please open the necessary files from the Nabble.RAR file I have uploaded for
you.
Hope I was helpful
Cheers Ori Gudes
s r-7 wrote:
> ----- Forwarded Message ----
> From: Saka Royban <srph124 at yahoo.com>
> To: MapGuide <mapguide-users at lists.osgeo.org>
> Sent: Sunday, November 25, 2007 8:45:10 PM
> Subject: Really Need Help with MapGuide Studio and MGOS
> Hi all.
> I've encountered some problems using MapGuide Studio 2007 Preview with
> MGOS:
> 1. It sounds MGS doesn't work with MGOS 1.2RC2 because it shows the
> message ' MapGuide Studio is incompatible with this version of Site
> Server'. Am i right? (although i've downloaded that dll and install it)
> Installing MGOS 1.1, i had these problems:
> 2. I cannot load dwg files to MGS. I don't know why but according to its
> Getting Started i had to be able to do this.
> 3. When i wanna load Raster files to server it shows the message " Server
> does not support requested Provider: Autodesk.raster
> 4. I established an Access DB connection, after saving it and testing
> connection it returned some errors (error 599)
> 5. I wanted to style one of layers but i wasn't able to view that layer
> receiving this error "XML page cannot be displayed. A name was started
> with an invalid character. Error processing resource"
> I appreciate any help because i'm a newbie to MG
> THX a lot
> Never miss a thing. Make Yahoo your homepage.
> ____________________________________________________________________________________
> Be a better pen pal.
> Text or chat with friends inside Yahoo! Mail. See how.
> http://overview.mail.yahoo.com/
> mapguide-users mailing list
http://www.nabble.com/file/p14130715/nabble.rar nabble.rar
View this message in context: http://www.nabble.com/Why-Nobody-answers-me--Fw%3A-Really-Need-Help-with-MapGuide-Studio-and-MGOS-tf4931332s16610.html#a14130715
