[mapguide-users] RE: mapguide-users Digest, Vol 12, Issue 1
Kalaiselvan kalai.selvan at geo-edge.com
Mon Dec 3 00:57:43 EST 2007
With a clear explaination from Kenneth regarding the MapGuide Webstudio, can
we come to a conclusion that, at the moment MapGuide webstudio is somewhat
dummy, which shall be useful as MapGuide studio only if proper funding Or
some volunteers do some research on it Correct?
Regards,
Kalai Selvan..
Message: 20
Date: Sat, 01 Dec 2007 13:54:41 +0100
Subject: Re: [mapguide-users] Problem in loading SDF data in Mapguide
	Webstudio
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Message-ID: <47515991.5090701 at geograf.dk>
Content-Type: text/plain; charset="iso-8859-1"
MapGuide Studio is a ful product with Autodesk support.
WebStudio is an opensource web based product.
In essence they accomplish the same task, however WebStudio does not
have any direct funding.
This means that it will not always be stable/updated, unless some
volunteer does some work on it.
Currently there is no editor for WebLayouts in WebStudio.
This limitiation is quite severe, as the AJAX and DWF viewers are based
on a WebLayout.
In other words, you will not be able to build a solution that works
right away, using only WebStudio.
Secondly, there is no legal way for an opensource product to support
proprietary formats (such as DWG and ArcSDE).
MapGuide Studio can overcome this limitation, since it is not open source.
Regards, Kenneth, GEOGRAF A/S
Parvatha skrev:
> Hi Kenneth,
>  Thanks for your reply. The problem is not with sdf and with upload data
> only. With studio preview its working well. But i want to understand the
> need of web studio and its limitations.
> Thanks and Regards
> Parvatha
> Kenneth, GEOGRAF A/S wrote:
>> You should use the "Load Procedures" from within MapGuide Studio.
>> The load procedures are missing from WebStudio, because the Load
>> procedures read proprietary data formats and converts them to SDF for
>> use in the server.
>> WebStudio is missing the "Load Procedures" and currently an editor for
>> WebStudio.
>> What you describe means that there is no spatial data inside the loaded
>> SDF files.
>> Please try again with different data. If you suspect that the problem is
>> with the load procedures,
>> you can ask Autodesk for support.
>> Parvatha skrev:
>>> Can anybody help me to solve this issue in webstudio?
>>> Parvatha wrote:
>>>> Hi
>>>>  I am new to MapGuide Opensource. I have downloaded version 1.2 of MGOS
>>>> and it has got webstudio in that. I am using .NET 2 and able to see the
>>>> sample data.
>>>>  My problem is when i try to load SDF data the sytem takes few seconds
>>>> then in data file resources window its showing the file name. But when
i
>>>> create one layer and try to give this as data source its not showing
any
>>>> feature class and geometry. I dont know what is the problem in loading
>>>> the
>>>> sdf data. Can anybody please help me to solve this issue.
>>>>  I have downloaded the trail version of MG studio preview also. With
>>>> that
>>>> I am able to do all these things. But basically I want to understand
the
>>>> need of webstudio and the limitations. Is it necessary to do everything
>>>> in
>>>> MG studio only? then what is the purpose of web studio?
>>>> Thanks and waiting for the response
>>>> Parvatha
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
mapguide-users-request at lists.osgeo.org
Sent: Saturday, December 01, 2007 10:30 PM
To: mapguide-users at lists.osgeo.org
Subject: mapguide-users Digest, Vol 12, Issue 1
Send mapguide-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	mapguide-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of mapguide-users digest..."
Today's Topics:
   1. RE: Not much luck with ogr or postgis on 	Ubuntu (Joanne Cook)
   2. RE: Not much luck with ogr or postgis on 	Ubuntu (Traian Stanev)
   3. RE: Not much luck with ogr or postgis on 	Ubuntu (Jack Lee)
   4. RE: Not much luck with ogr or postgis on 	Ubuntu (Greg Boone)
   5. Re: Problem in loading SDF data in Mapguide Webstudio (stsampler)
   6. Re: Dynamically creating a line layer with SDF	Feature Source
      (stsampler)
   7. RE: MGOS 2 build freezing on Ubuntu 7.10 (Mange)
   8. RE: Not much luck with ogr or postgis on 	Ubuntu (Dave Wilson)
   9. Re: Trouble with rendering service (Kenneth, GEOGRAF A/S)
  10. Re: Change shape of polygon... (Kenneth, GEOGRAF A/S)
  11. Re: Problem in loading SDF data in Mapguide Webstudio
  12. RE: Change shape of polygon... (Jason Birch)
  13. RE: Not much luck with ogr or postgis on 	Ubuntu (Jason Birch)
  14. RE: Not much luck with ogr or postgis on 	Ubuntu (Jason Birch)
  15. RE: Not much luck with ogr or postgis on 	Ubuntu (Traian Stanev)
  16. RE: SUSPECT: RE: Printing (uXuf)
  17. RE: Not much luck with ogr or postgis on 	Ubuntu (Jason Birch)
  18. RE: SUSPECT: RE: [mapguide-users] SUSPECT: RE: Printing
      (Jason Birch)
  19. Re: Problem in loading SDF data in Mapguide Webstudio (Parvatha)
  20. Re: Problem in loading SDF data in Mapguide Webstudio
Message: 1
Date: Fri, 30 Nov 2007 17:34:53 +0000 (GMT)
Subject: RE: [mapguide-users] Not much luck with ogr or postgis on
	Ubuntu
Message-ID:
	<11256912.34511196444093127.JavaMail.root at mail.thehumanjourney.net>
Content-Type: text/plain; charset=utf-8
Hi All,
I seem to be unable to answer mailing list messages in nabble at the moment,
and only get the daily digest otherwise, so here goes:
1: Dave suggested there should be Provider.so files in the FDO/bin directory
but I don't have that- only /usr/local/fdo-3.3.0/lib and they are all in
there. Doing a search for one of the other providers seems to suggest that's
the only location for all of them, which may be wrong?
2: Running ldd -r on libPostGISProvider.so gives me the following line that
I don't get when I run any of the others (including ogr): undefined symbol:
crypt (./libPostGISProvider.so)
3: Not sure how to use LD_LIBRARY_PATH, but running echo $LD_LIBRARY_PATH
doesn't give me anything
Thanks for all the replies
Jo
Message: 40
Date: Fri, 30 Nov 2007 08:38:14 -0800
	Ubuntu
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>,
	<fdo-internals at lists.osgeo.org>
Message-ID:
	<8E468917B01800408B91984428BE03DD072A5C74 at starfish.nanaimo.ca>
Content-Type: text/plain;	charset="US-ASCII"
I ran into the same problem the last time I checked.  Perhaps we need to
put the PostGIS and OGR shared libraries into the include path before
running MapGuide or something?  I unfortunately don't know enough about
this stuff works on *nix to be able to figure out where to start.  Is
there something equivalent to depends.exe on windows?
Are the .so files for the drivers to talk to PostGIS or OGR in some
directory other than the FDO/bin directory? If so then add the path to the
LD_LIBRARY_PATH and try again. Otherwise copy the .so files into the FDO/bin
folder.
At least that's how the other FDO providers work. The.so files need to be in
the same folder or in the system path.
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, November 30, 2007 9:38 AM
To: MapGuide Users Mail List; fdo-internals at lists.osgeo.org
Subject: RE: [mapguide-users] Not much luck with ogr or postgis on Ubuntu
I can't start my VM right now, but if you look in your FDO directory,
can you see whether the appropriate provider library files were built
for these?
Any FDO folks have any ideas about this?
Jason
Files attached to this email may be in ISO 26300 format (OASIS Open Document
Format). If you have difficulty opening them, please visit
http://iso26300.info for more information.
Message: 2
Date: Fri, 30 Nov 2007 09:46:36 -0800
From: Traian Stanev <traian.stanev at autodesk.com>
	Ubuntu
Message-ID:
<D20FC5C02CA4AB41891CFE76D91C57A91287752440 at ADSK-NAMSG-02.MGDADSK.autodesk.c
om>
Content-Type: text/plain; charset="us-ascii"
Could you open providers.xml (should be under your fdo-3.3.0/lib) and find
the entries for the PostGIS and OGR providers, then send us those snippets?
Traian
______________________________
[mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joanne Cook
[j.cook at oxfordarch.co.uk]
Sent: Friday, November 30, 2007 12:34 PM
Ubuntu
Hi All,
Jo
Message: 40
        Ubuntu
Message-ID:
folder.
Dave
for these?
Jason
Message: 3
Date: Fri, 30 Nov 2007 10:09:04 -0800
	Ubuntu
Message-ID:
<D8305E7409B5DB46A9D6219E54E1CF1A1773F6B4F8 at ADSK-NAMSG-01.MGDADSK.autodesk.c
om>
The crypt library seems to be missing from PostGIS/Src/Makefile.am
You can try changing
   -lpq
to
  -lpq \
  -lcrypt
in Makefile.am and rebuild.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joanne Cook
Sent: Freitag, 30. November 2007 12:35
Hi All,
Jo
Message: 40
        Ubuntu
Message-ID:
folder.
Dave
for these?
Jason
Message: 4
Date: Fri, 30 Nov 2007 10:16:43 -0800
	Ubuntu
Message-ID:
<C58680A9E35DCE45A8F1A3CA451C4DA317854AC562 at ADSK-NAMSG-01.MGDADSK.autodesk.c
om>
Please generate an FDO Ticket to track this issue so it can be resolved in
an upcoming build/release.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jack Lee
Sent: Friday, November 30, 2007 1:09 PM
   -lpq
to
  -lpq \
  -lcrypt
Hi All,
Jo
Message: 40
        Ubuntu
Message-ID:
folder.
Dave
for these?
Jason
Message: 5
Date: Fri, 30 Nov 2007 10:21:58 -0800 (PST)
	Webstudio
Message-ID: <14087757.post at talk.nabble.com>
Content-Type: text/plain; charset=us-ascii
Hi. Try to use mapagent to create the layer. For this, take an XML from
other
layer (with getResourceContent) and change it. Later, use setResourceContent
with your xml.
Regards.
Guillermo.
Parvatha wrote:
> Hi
> sample data.
> then in data file resources window its showing the file name. But when i
> create one layer and try to give this as data source its not showing any
> feature class and geometry. I dont know what is the problem in loading the
>  I have downloaded the trail version of MG studio preview also. With that
> I am able to do all these things. But basically I want to understand the
> need of webstudio and the limitations. Is it necessary to do everything in
> Parvatha
View this message in context:
http://www.nabble.com/Problem-in-loading-SDF-data-in-Mapguide-Webstudio-tf48
96513s16610.html#a14087757
Message: 6
Date: Fri, 30 Nov 2007 10:26:03 -0800 (PST)
Subject: Re: [mapguide-users] Dynamically creating a line layer with
	SDF	Feature Source
Message-ID: <14087759.post at talk.nabble.com>
I have a same problem. I quit the validation and works fine.
Regards.
Guillermo.
uXuf wrote:
> Hi all,
> I am trying to add a layer of lines to my map using an existing
> FeatureSource in the library. This FeatureSource was generated from an SDF
> (created by Map 3D). I want to create the layer using the
> LayerDefinitionFactory instead of the usual XML file way.
> However, I get a "The new XML document is invalid" error when I try to use
> the add_layer_definition_to_map() function of the
> LayerDefinitionFactory.php. Inspecting this problem it turns out that the
> layer definition that (I think) I am sending with the code is failing to
> validate with the LayerDefinition-1.0.0.xsd. I haven't touched the XSD
> file at all since installation. Probably this error could lie when I am
> creating my geometry, I checked in the examples and consistently it was
> specified as "SHPGEOM", however when I check it out in Studio by creating
> a temporary layer from the feature source it is specified as "Data". I
> have also checked by specifying geometry as "Data". The error remains so.
> Another thing I am getting confused in is to provide the Feature Name. I
> provide it with the value of "SDF_2_Schema:Selected", but I am not sure
> whether I should use "SHP_Schema:Selected". Any pointers in this regard
> would be greatly welcomed.
> Here is the relevant part of my code:
> //Set up a temporary layer
> $factory = new LayerDefinitionFactory();
> $legendLabel = '';
> $filter = '';
> $color = 'FF0000FF';
> $lineRule = $factory->CreateLineRule($legendLabel, $filter, $color);
> $lineTypeStyle = $factory->CreateLineTypeStyle($lineRule);
> $minScale = '0';
> $maxScale = '1000000';
> $lineScaleRange = $factory->CreateScaleRange($minScale, $maxScale,
> $lineTypeStyle);
> //The following FeatureSource is generated from and SDF
> $featureClass = "Library://akMaps/Data/Arteries.FeatureSource";
> //Could this be the real culprit?
> $featureName = "SDF_2_Schema:Selected";
> //Or this?
> $geometry = 'Data';
> $layerDefinition = $factory->CreateLayerDefinition($featureClass,
> $featureName, $geometry, $lineScaleRange);
> //error occurs in this function, fails to validate with
> LayerDefinition.xsd
> $newLayer = add_layer_definition_to_map($layerDefinition, "Selected",
> "Selected", $mgSessionID, $resourceService, $map);
> Any help would be greatly appreciated.
> Thanks in advance,
> uXuf
http://www.nabble.com/Dynamically-creating-a-line-layer-with-SDF-Feature-Sou
rce-tf4893966s16610.html#a14087759
Message: 7
Date: Fri, 30 Nov 2007 11:10:02 -0800 (PST)
Subject: RE: [mapguide-users] MGOS 2 build freezing on Ubuntu 7.10
Message-ID: <14089867.post at talk.nabble.com>
Hi guys, I applied the patch (not with curl) by simply adding the missing
lines in the makefile. Now the server is up and running. . .Now I will try
to discover the fusion package. . .
Thanks for the quick response on this ticket!
/Mange
Mange wrote:
> I got as far as you did. The make file crashed on the liblib_json.so.
> I may also mention that I first installed Ubuntu 7.10 64-bit server. Then
> you could not install fdo-3.3.0. So I reinstalled the 32-bit version.
> /Mange
> JasonBirch wrote:
>> Hmm...
>> I just got through building 2517 (mostly) and I think I got farther than
>> you did but then ran into a missing jsoncpp reference:
>> http://trac.osgeo.org/mapguide/ticket/347
>> Jason
>> From: Jo Cook
>> It's revision 2514, updated earlier on today
http://www.nabble.com/MGOS-2-build-freezing-on-Ubuntu-7.10-tf4881293s16610.h
tml#a14089867
Message: 8
Date: Fri, 30 Nov 2007 11:39:24 -0800
	Ubuntu
Message-ID:
<53C1C94B2F19CD408BFA392599EAF8E21287E1FF64 at ADSK-NAMSG-02.MGDADSK.autodesk.c
om>
Doh. I'm a Windohs use and forgot to swap bin with lib. LD_LIBRARY_PATH is
one way to set a path to search for files similar to the PATH variable in
Windows. I am not familiar with PostGIS or OGR, but for most stuff you need
some kind of client or connectivity files. If these are installed someplace
else then FDO needs to find them hence the path approach. The alternative is
to copy the required files to the FDO directory. That's it in a general
sense.
Unless of course our build does some kind of magic and builds the
connectivity into the provider which is entirely possible. I don't know
because I'm not a developer and don't know any details about the provider. I
was just providing a point of reference from my QA perspective.
Regards,
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Friday, November 30, 2007 11:17 AM
   -lpq
to
  -lpq \
  -lcrypt
Hi All,
Jo
Message: 40
        Ubuntu
Message-ID:
folder.
Dave
for these?
Jason
Message: 9
Date: Fri, 30 Nov 2007 22:52:11 +0100
Subject: Re: [mapguide-users] Trouble with rendering service
Message-ID: <4750860B.5020903 at geograf.dk>
I have not used this for a while, as I found it borderline useless with
the reader complications.
As I recall, you cannot exhaust the MgByteReader by a single call.
You must itterate over the reader, and read 8K blocks for each itteration.
As I wrote, you should be able to find working code by searhing the posts.
If you find it, the Code Wiki is at:
http://trac.osgeo.org/mapguide/wiki/CodeSamples
monegodj skrev:
> This snippet is where I connect to the rendering service, call it, and
then
> write to the HTML response (and to file, to test the call). I've cut out
> setting up the selection and the map connection (sel and map) to keep this
> brief.
>         MgRenderingService sRendering =
(MgRenderingService)connection.CreateService(MgServiceType.RenderingService)
>         MgByteReader mapguideImageData = sRendering.RenderMap(map, sel,
> "JPG");
>         byte[] imageData = new byte[mapguideImageData.GetLength()];
>         mapguideImageData.Read(imageData, 0);
>         Response.ContentType = mapguideImageData.GetMimeType();
>         Response.BinaryWrite(imageData);
>         Response.End();
>         FileStream f = (new
> FileInfo(@"D:\test.jpg")).Open(FileMode.OpenOrCreate, FileAccess.Write);
>         using(f)
>             foreach(byte b in imageData)
>                 f.WriteByte(b);
>> I have worked some with the rendering service in .Net.
>> Is the byte array the size you expect?
>> Can you post a code snippet with the code you try to run?
URL:
http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071130/7809e27
8/attachment-0001.html
Message: 10
Date: Fri, 30 Nov 2007 23:00:54 +0100
Subject: Re: [mapguide-users] Change shape of polygon...
Message-ID: <47508816.9020405 at geograf.dk>
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
I have not yet speed tested the new server.
I can confirm that OpenLayers will download a larger image than
necessary, which is nice for panning, but an overhead otherwise.
Up until now, the 2.0 seems backwards compatible with 1.2.
I think the 2.0 is quite delayed:
http://trac.osgeo.org/mapguide/roadmap
Maciej Skorczewski skrev:
> Hi Kenneth!
> thx for info i will try this ...btw when MG 2.0 will have final relase?
> as i read some post there are problem whit speed...did you try beta
> relase? it is hard to change all existen project into new MG 2.0 ?
> Regards ,maciek
> PROCAD SA
> Autodesk Authorized Value Added Reseller
> www.procad.pl
> > Kenneth, GEOGRAF A/S pisze:
>> Hi Maciek.
>> There is a provider in the Fusion demo, that actually use OpenLayers.
>> If you install the 2.0 Beta, there is a provider in
>> "www\Fusion\lib\OpenLayers.js".
>> With that provider, it is fairly easy to get the Digitizing samples
>> working.
Message: 11
Date: Fri, 30 Nov 2007 23:06:03 +0100
	Webstudio
Message-ID: <4750894B.2040305 at geograf.dk>
use in the server.
WebStudio.
SDF files.
> Parvatha wrote:
>> Hi
>> sample data.
the
in
>> Parvatha
URL:
http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071130/cd58ae3
1/attachment-0001.html
Message: 12
Date: Fri, 30 Nov 2007 14:35:43 -0800
Subject: RE: [mapguide-users] Change shape of polygon...
Message-ID:
	<8E468917B01800408B91984428BE03DD072A5C81 at starfish.nanaimo.ca>
The Trac roadmap is not exactly up to date.  At our last PSC meeting we
talked about the release timeline:
http://trac.osgeo.org/mapguide/wiki/PscMeeting11-01-2007
which is constrained by the FDO timeline to some extent:
http://fdo.osgeo.org/roadMap.html
Based on this conversation, I would guess that we're not looking at a
final release of MGOS until February if all goes well with the betas and
RCs.
So this is a good time for me to stress how important it is to download
MGOS 2.0 beta and take it for a test spin with your existing
applications and data, especially if you have outstanding tickets on
1.2.x.  Given that Autodesk is still writing the majority of the
MapGuide code and are on a fixed development cycle, issues that are not
discovered during this beta process are far less likely to be fixed
quickly.
Jason
> Hi Kenneth!
relase?
> Regards ,maciek
> PROCAD SA
> Autodesk Authorized Value Added Reseller www.procad.pl
>> Hi Maciek.
>> working.
Message: 13
Date: Fri, 30 Nov 2007 14:49:14 -0800
	Ubuntu
Message-ID:
	<8E468917B01800408B91984428BE03DD072A5C82 at starfish.nanaimo.ca>
Done:
http://trac.osgeo.org/fdo/ticket/188
Jason
Ubuntu
in an upcoming build/release.
Message: 14
Date: Fri, 30 Nov 2007 16:05:03 -0800
	Ubuntu
Message-ID:
	<8E468917B01800408B91984428BE03DD072A5C86 at starfish.nanaimo.ca>
Here are the ones from my local Ubuntu build:
  <FeatureProvider>
    <Name>OSGeo.OGR.3.3</Name>
    <DisplayName>OSGeo FDO Provider for OGR</DisplayName>
    <Description>Access to OGR data sources</Description>
    <IsManaged>False</IsManaged>
    <Version>3.3.0.0</Version>
    <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
<LibraryPath>/usr/local/fdo-3.3.0/lib/libOGRProvider.so</LibraryPath>
 </FeatureProvider>
 <FeatureProvider>
    <Name>OSGeo.PostGIS.3.3</Name>
    <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
    <Description>Read/write access to spatial and attribute data in an
PostGIS.</Description>
<LibraryPath>/usr/local/fdo-3.3.0/lib/libPostGISProvider.so</LibraryPath
  </FeatureProvider>
Both of these are symlinks to the 3.3.0 versions.
Jason
Ubuntu
find the entries for the PostGIS and OGR providers, then send us those
snippets?
Message: 15
Date: Fri, 30 Nov 2007 17:08:29 -0800
	Ubuntu
Message-ID:
<D20FC5C02CA4AB41891CFE76D91C57A91287752C76 at ADSK-NAMSG-02.MGDADSK.autodesk.c
om>
Do you get the same errors as Jo Cook on your build?
Traian
Sent: Friday, November 30, 2007 7:05 PM
  <FeatureProvider>
 </FeatureProvider>
 <FeatureProvider>
  </FeatureProvider>
Jason
Ubuntu
snippets?
Message: 16
Date: Fri, 30 Nov 2007 17:37:27 -0800 (PST)
Subject: RE: [mapguide-users] SUSPECT: RE: Printing
Message-ID: <14101227.post at talk.nabble.com>
So who'd take the initiative for actually putting up further useful samples?
uXuf
ctallman wrote:
> Dennis,
> Thanks for sharing your work with the group.
> Chris
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonio,
> Dennis (Aviation)
> Sent: Wednesday, November 21, 2007 3:40 PM
> Subject: RE: SUSPECT: RE: [mapguide-users] Printing
> Chris, Martin, Maksim
> After working through our various "virus scanner" and "router port
> closed" issues. Jason has the zip and has already started putting
> together the page for your access. It is not obvious to me how it will
> be accessible but I am sure he knows the way and will let us know.
> Again ... thank you Jason.
> Happy Turkey Day!!!
> dennis
> Sent: Wednesday, November 21, 2007 1:23 PM
> Hi Dennis,
> The main osgeo wiki (wiki.osgeo.org) is different technology than the
> wiki in the MapGuide Trac instance, and does use OSGeo IDs.  We don't
> have single-sign-on though, so if you want to log in to the MapGuide
> wiki, you have to click on the "Login" link under the search box and log
> in there, not through the main OSGeo web site.  And you have to log in
> every time you visit the site; it doesn't remember your credentials.
> I'd be happy to post the zip and a description if you want to email it
> to me offline.  My tech group just started allowing zipfiles through
> again, so maybe I'll get lucky, but maybe not.  If not, I'll reply with
> FTP details you can use.
> Jason
> Dennis (Aviation)
> Sent: Wednesday, November 21, 2007 09:38
> Subject: SUSPECT: RE: [mapguide-users] Printing
> Jason,
> I have just read this:
> The following services do not yet use the central OSGeo userid.
> *         Wiki <http://wiki.osgeo.org/> : The main OSGeo wiki uses it's
> own userid list for those wanting to edit, but it is easy to signup for
> a wiki userid. Please make sure to add your email address to the
> appropriate field because it is used to verify you are a real person.
> Before that it is not possible to edit the Wiki.
> *         Shell access to the telascience blades used for various
> project services (ie. buildbot.osgeo.org, buildbot.osgeo.org).
> *         Shell access to primary OSGeo server - available by special
> arrangement with the System Administration Committee
> This then explains why I never see .. "logged in as xxx"
> ... and frankly all this is getting to be a bit much for me.
> I do not wish to be forward and impose but why don't I email you the ZIP
> and you then can post it? There is a README that explains.
> This would also give you a chance to review the contents first.
> dennis
> E-mails are automatically scanned for viruses using McAfee.
http://www.nabble.com/Printing-tf4836766s16610.html#a14101227
Message: 17
Date: Fri, 30 Nov 2007 17:37:10 -0800
	Ubuntu
Message-ID:
	<8E468917B01800408B91984428BE03DD05C56F27 at starfish.nanaimo.ca>
Last time I tried, I was unable to connect to PostGIS:
http://tinyurl.com/3aew5l
I'm most of the way through a full clean rebuild right now (verifying the
previous problem with the CGI agent) and will test once I get up and running
again.
Jason
Name: not available
Type: application/ms-tnef
Desc: not available
Url :
http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071130/b742256
2/attachment-0001.bin
Message: 18
Date: Fri, 30 Nov 2007 17:41:40 -0800
Subject: RE: SUSPECT: RE: [mapguide-users] SUSPECT: RE: Printing
Message-ID:
	<8E468917B01800408B91984428BE03DD05C56F28 at starfish.nanaimo.ca>
Anybody who has interesting code to contribute is certainly welcome...
Jason
Subject: SUSPECT: RE: [mapguide-users] SUSPECT: RE: Printing
Name: not available
Desc: not available
Url :
http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071130/4572bc0
3/attachment-0001.bin
Message: 19
Date: Fri, 30 Nov 2007 21:56:00 -0800 (PST)
	Webstudio
Message-ID: <14102518.post at talk.nabble.com>
Hi Kenneth,
Thanks and Regards
Parvatha
> use in the server.
> WebStudio.
> SDF files.
>> Parvatha wrote:
>>> Hi
>>> sample data.
>>> the
>>> that
>>> in
>>> Parvatha
96513s16610.html#a14102518
Message: 20
	Webstudio
on a WebLayout.
Parvatha skrev:
> Hi Kenneth,
> Thanks and Regards
> Parvatha
>> use in the server.
>> WebStudio.
>> SDF files.
>>> Parvatha wrote:
>>>> Hi
>>>> sample data.
i
any
>>>> the
>>>> that
the
>>>> in
>>>> Parvatha
URL:
http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071201/b9ce5e9
e/attachment-0001.html
End of mapguide-users Digest, Vol 12, Issue 1
