[ZS3] [mapguide-users] RE: mapguide-users Digest, Vol 12, Issue 1
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Dec 3 03:27:10 EST 2007
I'm not sure what the official status of WebStudio is, but so far it is
still being actively developed.
It functions as a platform independent editor, where MapGuide Studio is
Windows only.
I believe that the current maintainer is "DM Solutions".
They have also donated the Fusion framework, and I think they have focus
on this, rather than the WebLayout.
I would not call WebStudio a "dummy", but it does not give a complete
MapGuide Studio replacement.
If you want to use the proprietary formats, you have to use MapGuide Studio.
Regards, Kenneth, GEOGRAF A/S
Kalaiselvan skrev:
> With a clear explaination from Kenneth regarding the MapGuide Webstudio, can
> we come to a conclusion that, at the moment MapGuide webstudio is somewhat
> dummy, which shall be useful as MapGuide studio only if proper funding Or
> some volunteers do some research on it Correct?
> Regards,
> Kalai Selvan..
> Message: 20
> Date: Sat, 01 Dec 2007 13:54:41 +0100
> From: "Kenneth, GEOGRAF A/S" <ks at geograf.dk>
> Subject: Re: [mapguide-users] Problem in loading SDF data in Mapguide
> Webstudio
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Message-ID: <47515991.5090701 at geograf.dk>
> Content-Type: text/plain; charset="iso-8859-1"
> MapGuide Studio is a ful product with Autodesk support.
> WebStudio is an opensource web based product.
> In essence they accomplish the same task, however WebStudio does not
> have any direct funding.
> This means that it will not always be stable/updated, unless some
> volunteer does some work on it.
> Currently there is no editor for WebLayouts in WebStudio.
> This limitiation is quite severe, as the AJAX and DWF viewers are based
> on a WebLayout.
> In other words, you will not be able to build a solution that works
> right away, using only WebStudio.
> Secondly, there is no legal way for an opensource product to support
> proprietary formats (such as DWG and ArcSDE).
> MapGuide Studio can overcome this limitation, since it is not open source.
> Parvatha skrev:
>> Hi Kenneth,
>> Thanks for your reply. The problem is not with sdf and with upload data
>> only. With studio preview its working well. But i want to understand the
>> need of web studio and its limitations.
>> Thanks and Regards
>> Parvatha
>> Kenneth, GEOGRAF A/S wrote:
>>> You should use the "Load Procedures" from within MapGuide Studio.
>>> The load procedures are missing from WebStudio, because the Load
>>> procedures read proprietary data formats and converts them to SDF for
>>> use in the server.
>>> WebStudio is missing the "Load Procedures" and currently an editor for
>>> WebStudio.
>>> What you describe means that there is no spatial data inside the loaded
>>> SDF files.
>>> Please try again with different data. If you suspect that the problem is
>>> with the load procedures,
>>> you can ask Autodesk for support.
>>> Parvatha skrev:
>>>> Can anybody help me to solve this issue in webstudio?
>>>> Parvatha wrote:
>>>>> Hi
>>>>> I am new to MapGuide Opensource. I have downloaded version 1.2 of MGOS
>>>>> and it has got webstudio in that. I am using .NET 2 and able to see the
>>>>> sample data.
>>>>> My problem is when i try to load SDF data the sytem takes few seconds
>>>>> then in data file resources window its showing the file name. But when
> i
>>>>> create one layer and try to give this as data source its not showing
> any
>>>>> feature class and geometry. I dont know what is the problem in loading
>>>>> the
>>>>> sdf data. Can anybody please help me to solve this issue.
>>>>> I have downloaded the trail version of MG studio preview also. With
>>>>> that
>>>>> I am able to do all these things. But basically I want to understand
> the
>>>>> need of webstudio and the limitations. Is it necessary to do everything
>>>>> in
>>>>> MG studio only? then what is the purpose of web studio?
>>>>> Thanks and waiting for the response
>>>>> Parvatha
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
> mapguide-users-request at lists.osgeo.org
> Sent: Saturday, December 01, 2007 10:30 PM
> To: mapguide-users at lists.osgeo.org
> Subject: mapguide-users Digest, Vol 12, Issue 1
> Send mapguide-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> mapguide-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of mapguide-users digest..."
> Today's Topics:
> 1. RE: Not much luck with ogr or postgis on Ubuntu (Joanne Cook)
> 2. RE: Not much luck with ogr or postgis on Ubuntu (Traian Stanev)
> 3. RE: Not much luck with ogr or postgis on Ubuntu (Jack Lee)
> 4. RE: Not much luck with ogr or postgis on Ubuntu (Greg Boone)
> 5. Re: Problem in loading SDF data in Mapguide Webstudio (stsampler)
> 6. Re: Dynamically creating a line layer with SDF Feature Source
> (stsampler)
> 7. RE: MGOS 2 build freezing on Ubuntu 7.10 (Mange)
> 8. RE: Not much luck with ogr or postgis on Ubuntu (Dave Wilson)
> 9. Re: Trouble with rendering service (Kenneth, GEOGRAF A/S)
> 10. Re: Change shape of polygon... (Kenneth, GEOGRAF A/S)
> 11. Re: Problem in loading SDF data in Mapguide Webstudio
> 12. RE: Change shape of polygon... (Jason Birch)
> 13. RE: Not much luck with ogr or postgis on Ubuntu (Jason Birch)
> 14. RE: Not much luck with ogr or postgis on Ubuntu (Jason Birch)
> 15. RE: Not much luck with ogr or postgis on Ubuntu (Traian Stanev)
> 16. RE: SUSPECT: RE: Printing (uXuf)
> 17. RE: Not much luck with ogr or postgis on Ubuntu (Jason Birch)
> 18. RE: SUSPECT: RE: [mapguide-users] SUSPECT: RE: Printing
> (Jason Birch)
> 19. Re: Problem in loading SDF data in Mapguide Webstudio (Parvatha)
> 20. Re: Problem in loading SDF data in Mapguide Webstudio
> Message: 1
> Date: Fri, 30 Nov 2007 17:34:53 +0000 (GMT)
> From: Joanne Cook <j.cook at oxfordarch.co.uk>
> Subject: RE: [mapguide-users] Not much luck with ogr or postgis on
> Ubuntu
> Message-ID:
> <11256912.34511196444093127.JavaMail.root at mail.thehumanjourney.net>
> Content-Type: text/plain; charset=utf-8
> Hi All,
> I seem to be unable to answer mailing list messages in nabble at the moment,
> and only get the daily digest otherwise, so here goes:
> 1: Dave suggested there should be Provider.so files in the FDO/bin directory
> but I don't have that- only /usr/local/fdo-3.3.0/lib and they are all in
> there. Doing a search for one of the other providers seems to suggest that's
> the only location for all of them, which may be wrong?
> 2: Running ldd -r on libPostGISProvider.so gives me the following line that
> I don't get when I run any of the others (including ogr): undefined symbol:
> crypt (./libPostGISProvider.so)
> 3: Not sure how to use LD_LIBRARY_PATH, but running echo $LD_LIBRARY_PATH
> doesn't give me anything
> Thanks for all the replies
> Jo
> Message: 40
> Date: Fri, 30 Nov 2007 08:38:14 -0800
> From: "Jason Birch" <Jason.Birch at nanaimo.ca>
> Ubuntu
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>,
> <fdo-internals at lists.osgeo.org>
> Message-ID:
> <8E468917B01800408B91984428BE03DD072A5C74 at starfish.nanaimo.ca>
> Content-Type: text/plain; charset="US-ASCII"
> I ran into the same problem the last time I checked. Perhaps we need to
> put the PostGIS and OGR shared libraries into the include path before
> running MapGuide or something? I unfortunately don't know enough about
> this stuff works on *nix to be able to figure out where to start. Is
> there something equivalent to depends.exe on windows?
> Are the .so files for the drivers to talk to PostGIS or OGR in some
> directory other than the FDO/bin directory? If so then add the path to the
> LD_LIBRARY_PATH and try again. Otherwise copy the .so files into the FDO/bin
> folder.
> At least that's how the other FDO providers work. The.so files need to be in
> the same folder or in the system path.
> Dave
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Friday, November 30, 2007 9:38 AM
> To: MapGuide Users Mail List; fdo-internals at lists.osgeo.org
> Subject: RE: [mapguide-users] Not much luck with ogr or postgis on Ubuntu
> I can't start my VM right now, but if you look in your FDO directory,
> can you see whether the appropriate provider library files were built
> for these?
> Any FDO folks have any ideas about this?
> Jason
> Files attached to this email may be in ISO 26300 format (OASIS Open Document
> Format). If you have difficulty opening them, please visit
> http://iso26300.info for more information.
> Message: 2
> Date: Fri, 30 Nov 2007 09:46:36 -0800
> From: Traian Stanev <traian.stanev at autodesk.com>
> Ubuntu
> Message-ID:
> <D20FC5C02CA4AB41891CFE76D91C57A91287752440 at ADSK-NAMSG-02.MGDADSK.autodesk.c
> om>
> Content-Type: text/plain; charset="us-ascii"
> Could you open providers.xml (should be under your fdo-3.3.0/lib) and find
> the entries for the PostGIS and OGR providers, then send us those snippets?
> Traian
> ______________________________
> [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joanne Cook
> [j.cook at oxfordarch.co.uk]
> Sent: Friday, November 30, 2007 12:34 PM
> Ubuntu
> Hi All,
> Jo
> Message: 40
> Ubuntu
> Message-ID:
> folder.
> Dave
> for these?
> Jason
> Message: 3
> Date: Fri, 30 Nov 2007 10:09:04 -0800
> From: Jack Lee <jack.lee at autodesk.com>
> Ubuntu
> Message-ID:
> <D8305E7409B5DB46A9D6219E54E1CF1A1773F6B4F8 at ADSK-NAMSG-01.MGDADSK.autodesk.c
> om>
> Hi,
> The crypt library seems to be missing from PostGIS/Src/Makefile.am
> You can try changing
> -lpq
> to
> -lpq \
> -lcrypt
> in Makefile.am and rebuild.
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joanne Cook
> Sent: Freitag, 30. November 2007 12:35
> Hi All,
> Jo
> Message: 40
> Ubuntu
> Message-ID:
> folder.
> Dave
> for these?
> Jason
> Message: 4
> Date: Fri, 30 Nov 2007 10:16:43 -0800
> From: Greg Boone <greg.boone at autodesk.com>
> Ubuntu
> Message-ID:
> <C58680A9E35DCE45A8F1A3CA451C4DA317854AC562 at ADSK-NAMSG-01.MGDADSK.autodesk.c
> om>
> Please generate an FDO Ticket to track this issue so it can be resolved in
> an upcoming build/release.
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jack Lee
> Sent: Friday, November 30, 2007 1:09 PM
> Hi,
> -lpq
> to
> -lpq \
> -lcrypt
> Hi All,
> Jo
> Message: 40
> Ubuntu
> Message-ID:
> folder.
> Dave
> for these?
> Jason
> Message: 5
> Date: Fri, 30 Nov 2007 10:21:58 -0800 (PST)
> From: stsampler <guillle at gmail.com>
> Webstudio
> Message-ID: <14087757.post at talk.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Hi. Try to use mapagent to create the layer. For this, take an XML from
> other
> layer (with getResourceContent) and change it. Later, use setResourceContent
> with your xml.
> Regards.
> Guillermo.
> Parvatha wrote:
>> Hi
>> sample data.
>> then in data file resources window its showing the file name. But when i
>> create one layer and try to give this as data source its not showing any
>> feature class and geometry. I dont know what is the problem in loading the
>> I have downloaded the trail version of MG studio preview also. With that
>> I am able to do all these things. But basically I want to understand the
>> need of webstudio and the limitations. Is it necessary to do everything in
>> Parvatha
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071203/b384415f/attachment.html
