[mapguide-users] Problem in loading SDF data in Mapguide Webstudio
Parvatha kpeswari at indiainfo.com
Mon Dec 3 07:51:44 EST 2007
Hi Kenneth,
 I am clear with studio and web studio now. As you suggested I have tried
loading someother SDF (world.sdf) in web studio. But that is also not
getting uploaded. I have attached the screenshot of the result also. Even I
have installed freshly and tried then also the same problem. I want to know
where is the problem exactly.
I have created the folder called "world" then i have created one feature
data named "world data" and then i have created layer named "world layer"
then i gave the world data source.
Do i need to keep sdf in any separate folder? Can you please tell me the
sequence of loading sdf data?
Otherwise do I need to create only .mgp files and load all the layers?
Because the sample sheboygan data is in .mgp format. When I load this using
load packages in admin login form then only the sdf's are getting loaded in
the data folder.
Can you please clarify my doubt?
Thanks and Regards
Parvatha
http://www.nabble.com/file/p14128091/data-err.bmp data-err.bmp
http://www.nabble.com/file/p14128091/layer-err.bmp layer-err.bmp
View this message in context: http://www.nabble.com/Problem-in-loading-SDF-data-in-Mapguide-Webstudio-tf4896513s16610.html#a14128091
