[mapguide-users] Problem in loading SDF data in Mapguide Webstudio
Parvatha
kpeswari at indiainfo.com
Tue Dec 4 08:49:17 EST 2007
Zak,
Thans for your reply. PHP is there already there within the opensource
folder itself(default).
Still I have installed the latest php and tried loading the sample sdf
(sheboygan) data only but the same problem again. I think still I am missing
something and got stuck. I have loaded the mgp smaple data and the sdfs are
loaded in the data folder. From that folder i have taken the sample data
and tried loading.
Using mapagent also i am trying to load the data. I am able to copy the
resource from sample data but i am unable to findfout the xml to replace my
own sdf data.
can you help me?
Regards
Parvatha
Zak James wrote:
> Parvatha,
> I think it's wise to try loading an sdf from the Sheboygan sample to
> understand if the issue is with your particular data or with
> Webstudio's upload facility. One think that might not have been
> mentioned yet is that the upload form in Webstudio requires that you
> have the PHP API installed. If you installed only .NET, that could
> explain what's going wrong.
> In terms of the broader issue of where Webstudio fits in the Mapguide
> system, it's worth pointing out that with the help of mapadmin, the
> mapagent utility and webstudio, you can build complete applications
> with Mapguide Open Source. There are many things made easier with
> Autodesk's commercial tool but there are only a few things that can't
> be done at all, mostly involving load procedures. In time, the efforts
> of Kenneth and others to develop additional tools may reduce the level
> of difficulty.
> zak
> On Dec 3, 2007 7:51 AM, Parvatha <kpeswari at indiainfo.com> wrote:
>> Hi Kenneth,
>> I am clear with studio and web studio now. As you suggested I have tried
>> loading someother SDF (world.sdf) in web studio. But that is also not
>> getting uploaded. I have attached the screenshot of the result also. Even
>> I
>> have installed freshly and tried then also the same problem. I want to
>> know
>> where is the problem exactly.
>> I have created the folder called "world" then i have created one feature
>> data named "world data" and then i have created layer named "world layer"
>> then i gave the world data source.
>> Do i need to keep sdf in any separate folder? Can you please tell me the
>> sequence of loading sdf data?
>> Otherwise do I need to create only .mgp files and load all the layers?
>> Because the sample sheboygan data is in .mgp format. When I load this
>> using
>> load packages in admin login form then only the sdf's are getting loaded
>> in
>> the data folder.
>> Can you please clarify my doubt?
>> Thanks and Regards
>> Parvatha
>> http://www.nabble.com/file/p14128091/data-err.bmp data-err.bmp
>> http://www.nabble.com/file/p14128091/layer-err.bmp layer-err.bmp
>> View this message in context:
>> http://www.nabble.com/Problem-in-loading-SDF-data-in-Mapguide-Webstudio-tf4896513s16610.html#a14128091
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zak James
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
View this message in context: http://www.nabble.com/Problem-in-loading-SDF-data-in-Mapguide-Webstudio-tf4896513s16610.html#a14150836
