[mapguide-users] Overlapping labels for points
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue Dec 4 09:34:14 EST 2007
Hmm. Maybe something to try would be turning on symbols....to see if
it's a bug that only occurs when you've got no symbols showing, but do
have labels.
Andrew
Christy Nieman wrote:
> Assuming that Studio is reporting correctly, "Labels are fixed (not
> dynamic)" and "Allow other labels to obscure feature symbols on this
> layer" are not checked. In the XML files AllowOverpost is false. I'm
> not certain, but I believe the problem only happens when there are no
> symbols being displayed with the labels (i.e. I have it set so that
> when at large scales, there are no symbols drawn, just the city name
> labels).
> Christy
> Andrew DeMerchant wrote:
>> Am I right in saying that your layers labels are not 'dynamic'? In MG
>> Studio, in the same area that you edit your label settings, you can
>> specify some additional settings....If you set them to be dynamic,
>> they shouldn't overlap - but that will cause some to not show up,
>> until you zoom in.
>> Andrew
>>> Hello all,
>>> I've been working with MapGuide OS for some time now and I've
>>> noticed a problem with labels for points overlapping. I have
>>> attached an image with an example of the problem I'm having. The
>>> Layers were created with MG Studio, and I'm using MGOS 1.2.
>>> While the attached image shows labels from several layers (same SDF
>>> feature source, different attribute filters), I have confirmed that
>>> the problem also happens with labels in the same layer. Has anyone
>>> seen this before? Is there a solution?
>>> Thanks,
>>> Christy
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
