[mapguide-users] Overlapping labels for points
Christy Nieman cnieman at dmsolutions.ca
Tue Dec 4 07:58:48 EST 2007
Assuming that Studio is reporting correctly, "Labels are fixed (not
dynamic)" and "Allow other labels to obscure feature symbols on this
layer" are not checked.  In the XML files AllowOverpost is false.  I'm
not certain, but I believe the problem only happens when there are no
symbols being displayed with the labels (i.e. I have it set so that when
at large scales, there are no symbols drawn, just the city name labels).
Christy
Andrew DeMerchant wrote:
> Am I right in saying that your layers labels are not 'dynamic'? In MG
> Studio, in the same area that you edit your label settings, you can
> specify some additional settings....If you set them to be dynamic,
> they shouldn't overlap - but that will cause some to not show up,
> until you zoom in.
> Andrew
> Christy Nieman wrote:
>> Hello all,
>> I've been working with MapGuide OS for some time now and I've noticed
>> a problem with labels for points overlapping.  I have attached an
>> image with an example of the problem I'm having.  The Layers were
>> created with MG Studio, and I'm using MGOS 1.2.
>> While the attached image shows labels from several layers (same SDF
>> feature source, different attribute filters), I have confirmed that
>> the problem also happens with labels in the same layer.  Has anyone
>> seen this before?  Is there a solution?
>> Thanks,
>> Christy
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
