[mapguide-users] Overlapping labels for points
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Mon Dec 3 12:19:06 EST 2007
Am I right in saying that your layers labels are not 'dynamic'? In MG
Studio, in the same area that you edit your label settings, you can
specify some additional settings....If you set them to be dynamic, they
shouldn't overlap - but that will cause some to not show up, until you
zoom in.
Andrew
Christy Nieman wrote:
> Hello all,
> I've been working with MapGuide OS for some time now and I've noticed
> a problem with labels for points overlapping. I have attached an
> image with an example of the problem I'm having. The Layers were
> created with MG Studio, and I'm using MGOS 1.2.
> While the attached image shows labels from several layers (same SDF
> feature source, different attribute filters), I have confirmed that
> the problem also happens with labels in the same layer. Has anyone
> seen this before? Is there a solution?
> Thanks,
> Christy
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
