[mapguide-users] feature class in mapguide studio
Zac Spitzer
zac.spitzer at gmail.com
Tue Dec 4 20:03:59 EST 2007
no they look fine, it was just a wild card.......
do they all have spatial indexes defined?
z
On Dec 5, 2007 1:29 AM, dorra2007 <dorrdor at yahoo.fr> wrote:
> The tables names: repere, historique, kangoo, test, interet, sol, route...
> I can get in maguide studio only: sol and route..
> Do you think that the other names are too long?
> zspitzer wrote:
> > in the old mapguide, if you had very long table names, the ide
> > (mapguide author?) would have
> > problems unless you made them shorter.... can you show us a list of
> > the table names?
> > On Dec 4, 2007 8:13 PM, dorra2007 <dorrdor at yahoo.fr> wrote:
> >> I have deleted and recreated the connection, sometimes have one new
> >> table
> >> reflected in mapguide studio, sometimes not.
> >> The most blocking thing is that in any case, the number of tables
> >> reflected
> >> doesn't exceed four. I mean, when I have more than four tables (7 for
> >> example), I have, as maximum, only four tables reflected in mapguide
> >> studio
> >> (if, of course, I succeed to get them in mapguide studio.)
> >> Have you encountered such problem (a max number of tables that can be
> >> displayed.)
> >> JotaroKujo wrote:
> >> > dorra2007 wrote:
> >> >> but when I want to update my database (I added new spatial table to
> >> the
> >> >> postgis database), the featureSource is not updated, and I can't
> >> create a
> >> >> new layer using the new table (because it's not displayed in the
> >> feature
> >> >> class list.)
> >> > I have found the same problem with Oracle 10g (I use the Autodesk
> >> > commercial FDO).
> >> > If you delete the connection, and recreate it...you will find the new
> >> > tables in the list.
> >> > May be when a connection is created, the server creates a file
> >> containing
> >> > the database catalogue structure.
> >> View this message in context:
> >> http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14147147
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > Zac Spitzer -
> > http://zacster.blogspot.com (My Blog)
> > +61 405 847 168
> View this message in context: http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14151701
Zac Spitzer -
+61 405 847 168
