[mapguide-users] feature class in mapguide studio
dorra2007 dorrdor at yahoo.fr
Wed Dec 5 04:26:12 EST 2007
Great, I create indexes on the geometry column and that resolves partially my
problem. In fact, I have to create a new feature source using the same
database to make updates effective.
Thank vey much you anyway.
zspitzer wrote:
> no they look fine, it was just a wild card.......
> do they all have spatial indexes defined?
> z
> On Dec 5, 2007 1:29 AM, dorra2007 <dorrdor at yahoo.fr> wrote:
>> The tables names: repere, historique, kangoo, test, interet, sol,
>> route...
>> I can get in maguide studio only: sol and route..
>> Do you think that the other names are too long?
>> zspitzer wrote:
>> > in the old mapguide, if you had very long table names, the ide
>> > (mapguide author?) would have
>> > problems unless you made them shorter.... can you show us a list of
>> > the table names?
>> > On Dec 4, 2007 8:13 PM, dorra2007 <dorrdor at yahoo.fr> wrote:
>> >> I have deleted and recreated the connection, sometimes  have one new
>> >> table
>> >> reflected in mapguide studio, sometimes not.
>> >> The most blocking thing is that in any case, the number of tables
>> >> reflected
>> >> doesn't exceed four. I mean, when I have more than four tables (7 for
>> >> example), I have, as maximum, only four tables reflected in mapguide
>> >> studio
>> >> (if, of course, I succeed to get them in mapguide studio.)
>> >> Have you encountered such problem (a max number of tables that can be
>> >> displayed.)
>> >> JotaroKujo wrote:
>> >> > dorra2007 wrote:
>> >> >> but when I want to update my database (I added  new spatial table
>> to
>> >> the
>> >> >> postgis database), the featureSource is not updated, and I can't
>> >> create a
>> >> >> new layer using the new table (because it's not displayed in the
>> >> feature
>> >> >> class list.)
>> >> > I have found the same problem with Oracle 10g (I use the Autodesk
>> >> > commercial FDO).
>> >> > If you delete the connection, and recreate it...you will find the
>> new
>> >> > tables in the list.
>> >> > May be when a connection is created, the server creates a file
>> >> containing
>> >> > the database catalogue structure.
>> >> View this message in context:
>> http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14147147
>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> mapguide-users mailing list
>> >> mapguide-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > Zac Spitzer -
>> > http://zacster.blogspot.com (My Blog)
>> > +61 405 847 168
>> http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14151701
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14168019
