[mapguide-users] feature class in mapguide studio
dorra2007 dorrdor at yahoo.fr
Wed Dec 5 05:10:36 EST 2007
Just one more question, if you don't mind. Which type of index is the most
appropriate in this case:
 B-tree, Hash, GiST or GIN. And the column which may be indexed is the
geometry column, isn't it?
dorra2007 wrote:
> Great, I create indexes on the geometry column and that resolves partially
> my problem. In fact, I have to create a new feature source using the same
> database to make updates effective.
> Thank vey much you anyway.
> zspitzer wrote:
>> no they look fine, it was just a wild card.......
>> do they all have spatial indexes defined?
>> z
>> On Dec 5, 2007 1:29 AM, dorra2007 <dorrdor at yahoo.fr> wrote:
>>> The tables names: repere, historique, kangoo, test, interet, sol,
>>> route...
>>> I can get in maguide studio only: sol and route..
>>> Do you think that the other names are too long?
>>> zspitzer wrote:
>>> > in the old mapguide, if you had very long table names, the ide
>>> > (mapguide author?) would have
>>> > problems unless you made them shorter.... can you show us a list of
>>> > the table names?
>>> > On Dec 4, 2007 8:13 PM, dorra2007 <dorrdor at yahoo.fr> wrote:
>>> >> I have deleted and recreated the connection, sometimes  have one new
>>> >> table
>>> >> reflected in mapguide studio, sometimes not.
>>> >> The most blocking thing is that in any case, the number of tables
>>> >> reflected
>>> >> doesn't exceed four. I mean, when I have more than four tables (7 for
>>> >> example), I have, as maximum, only four tables reflected in mapguide
>>> >> studio
>>> >> (if, of course, I succeed to get them in mapguide studio.)
>>> >> Have you encountered such problem (a max number of tables that can be
>>> >> displayed.)
>>> >> JotaroKujo wrote:
>>> >> > dorra2007 wrote:
>>> >> >> but when I want to update my database (I added  new spatial table
>>> to
>>> >> the
>>> >> >> postgis database), the featureSource is not updated, and I can't
>>> >> create a
>>> >> >> new layer using the new table (because it's not displayed in the
>>> >> feature
>>> >> >> class list.)
>>> >> > I have found the same problem with Oracle 10g (I use the Autodesk
>>> >> > commercial FDO).
>>> >> > If you delete the connection, and recreate it...you will find the
>>> new
>>> >> > tables in the list.
>>> >> > May be when a connection is created, the server creates a file
>>> >> containing
>>> >> > the database catalogue structure.
>>> >> View this message in context:
>>> http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14147147
>>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> >> _______________________________________________
>>> >> mapguide-users mailing list
>>> >> mapguide-users at lists.osgeo.org
>>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> > Zac Spitzer -
>>> > http://zacster.blogspot.com (My Blog)
>>> > +61 405 847 168
>>> http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14151701
>> Zac Spitzer -
>> +61 405 847 168
View this message in context: http://www.nabble.com/feature-class-in-mapguide-studio-tf4935604s16610.html#a14168482
