[mapguide-users] Published layers not showing using WMS -GetCapabilities
azpublic azpublic at bluewin.ch
Tue Dec 4 22:18:43 EST 2007
Thanks Zak,
This was helpful.
I finally found the way to publish a layer on the WMS using MapGuide studio
and the hidden "properties" dialog only accessible using a right click on
the layer in the site explorer ...
I know managed to publish my layer but it now seems I have some coordinate
problems.
The Shapefile I'm using has the following coordinates :
xMin,yMin 5.96611,45.8294 : xMax,yMax 10.4889,47.8069
However when trying to query these coordinates I get a blank image.
When using a WMS client such as Gaia or uDig I manage to see my layer but I
must zoom for hours for this and it seems that the map coordinates and scale
are not correct.
I've set the BOUNDS of the layer as follow :
<Bounds SRS=”EPSG:4326” north=”47.8069” west=”5.96611” south=”
45.8294” east=”10.4889” abstract=”true” />
However when looking at the layer properties in Gaia, I get the following
bounds :
xMin,yMin -180.00,-90.00 : xMax,yMax 180.00,90.00
Can someone help me fix this ? What am I doing wrong with the coords ?
Thanks in advance
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: mardi, 27. novembre 2007 10:31
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Published layers not showing using WMS
-GetCapabilities
you need to set the _ISPUBLISHED flag in the resourceheader xml
ie
Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition
contains
<?xml version="1.0" encoding="ISO-8859-1"?>
<ResourceDocumentHeader
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
   <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
      <Inherited>true</Inherited>
   </Security>
   <Metadata>
      <Simple>
         <Property xsi:noNamespaceSchemaLocation="Property-1.0.0.xsd">
            <Name>_ISPUBLISHED</Name>
            <Value>1</Value>
         </Property>
            <Name>_TITLE</Name>
            <Value>Sheboygan</Value>
         </Property>
            <Name>_QUERYABLE</Name>
            <Value>0</Value>
         </Property>
            <Name>_OPAQUE</Name>
            <Value>0</Value>
         </Property>
      </Simple>
   </Metadata>
</ResourceDocumentHeader>
On Nov 26, 2007 11:11 PM, azpublic <azpublic at bluewin.ch> wrote:
> Hi all,
> I've created a few layers using Mapguide Studio.
> Everything seems to work fine and I can create my maps and weblayout and
> view them using the AjaxViewer.
> However when I try to access theses layers using a WMS getImage request I
> don't' have anything…
> Furthermore when I use GetCapabilities using
> http://localhost:8008/mapguide/mapagent/getcapabilitieswmsform.html Here
is
> what I get in the resulting XML
>     PUBLISHED LAYERS
> <Layer>
> <Title>MapGuide WMS Server</Title>
> <SRS>EPSG:4326</SRS>
> <LatLonBoundingBox minx="-180" miny="-90" maxx="180" maxy="90"/>
> </Layer>
> </Capability>
> It seems that the layers I create using Mapguide Studio are not visible …
> Any Idea what I am doing wrong?
> Thanks for your help.
> Cheers
> Alex
> No virus found in this outgoing message.
>  Checked by AVG Free Edition.
>  Version: 7.5.503 / Virus Database: 269.16.7/1151 - Release Date:
25.11.2007
> 16:24
25.11.2007
> 16:24
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
No virus found in this incoming message.
Version: 7.5.503 / Virus Database: 269.16.8/1153 - Release Date: 26.11.2007
21:08
Version: 7.5.503 / Virus Database: 269.16.13 - Release Date: 02.12.2007
00:00
