[mapguide-users] Published layers not showing using WMS -GetCapabilities
Zac Spitzer zac.spitzer at gmail.com
Tue Dec 4 23:12:58 EST 2007
are the bounds showing up in the xml for GetCapabilities?
http://127.0.0.1:8008/mapguide/mapagent/mapagent.fcgi?REQUEST=GetCapabilities&service=WMS&&username=Administrator&password=admin
On Dec 5, 2007 2:18 PM, azpublic <azpublic at bluewin.ch> wrote:
> Thanks Zak,
> This was helpful.
> I finally found the way to publish a layer on the WMS using MapGuide studio
> and the hidden "properties" dialog only accessible using a right click on
> the layer in the site explorer ...
> I know managed to publish my layer but it now seems I have some coordinate
> problems.
> The Shapefile I'm using has the following coordinates :
> xMin,yMin 5.96611,45.8294 : xMax,yMax 10.4889,47.8069
> However when trying to query these coordinates I get a blank image.
> When using a WMS client such as Gaia or uDig I manage to see my layer but I
> must zoom for hours for this and it seems that the map coordinates and scale
> are not correct.
> I've set the BOUNDS of the layer as follow :
> <Bounds SRS="EPSG:4326" north="47.8069" west="5.96611" south="
> 45.8294" east="10.4889" abstract="true" />
> However when looking at the layer properties in Gaia, I get the following
> bounds :
> xMin,yMin -180.00,-90.00 : xMax,yMax 180.00,90.00
> Can someone help me fix this ? What am I doing wrong with the coords ?
> Thanks in advance
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: mardi, 27. novembre 2007 10:31
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Published layers not showing using WMS
> -GetCapabilities
> you need to set the _ISPUBLISHED flag in the resourceheader xml
> ie
> Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition
> contains
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <ResourceDocumentHeader
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
>    <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
>       <Inherited>true</Inherited>
>    </Security>
>    <Metadata>
>       <Simple>
>          <Property xsi:noNamespaceSchemaLocation="Property-1.0.0.xsd">
>             <Name>_ISPUBLISHED</Name>
>             <Value>1</Value>
>          </Property>
>             <Name>_TITLE</Name>
>             <Value>Sheboygan</Value>
>          </Property>
>             <Name>_QUERYABLE</Name>
>             <Value>0</Value>
>          </Property>
>             <Name>_OPAQUE</Name>
>             <Value>0</Value>
>          </Property>
>       </Simple>
>    </Metadata>
> </ResourceDocumentHeader>
> On Nov 26, 2007 11:11 PM, azpublic <azpublic at bluewin.ch> wrote:
> > Hi all,
> > I've created a few layers using Mapguide Studio.
> > Everything seems to work fine and I can create my maps and weblayout and
> > view them using the AjaxViewer.
> > However when I try to access theses layers using a WMS getImage request I
> > don't' have anything…
> > Furthermore when I use GetCapabilities using
> > http://localhost:8008/mapguide/mapagent/getcapabilitieswmsform.html Here
> is
> > what I get in the resulting XML
> >     PUBLISHED LAYERS
> > <Layer>
> > <Title>MapGuide WMS Server</Title>
> > <SRS>EPSG:4326</SRS>
> > <LatLonBoundingBox minx="-180" miny="-90" maxx="180" maxy="90"/>
> > </Layer>
> > </Capability>
> > It seems that the layers I create using Mapguide Studio are not visible …
> > Any Idea what I am doing wrong?
> > Thanks for your help.
> > Cheers
> > Alex
> > No virus found in this outgoing message.
> >  Checked by AVG Free Edition.
> >  Version: 7.5.503 / Virus Database: 269.16.7/1151 - Release Date:
> 25.11.2007
> > 16:24
> 25.11.2007
> > 16:24
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
> No virus found in this incoming message.
> Version: 7.5.503 / Virus Database: 269.16.8/1153 - Release Date: 26.11.2007
> 21:08
> Version: 7.5.503 / Virus Database: 269.16.13 - Release Date: 02.12.2007
> 00:00
Zac Spitzer -
+61 405 847 168
