[mapguide-users] Rasters de-serialize problem - help needed
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Wed Dec 5 02:34:17 EST 2007
hello group,
I'm having trouble with rasters on mapguide 1.2. I have successfully generated feature source from Brich's script and in mapguide studio I see that new resource. The problem occurred when I try to create new layer with this resource. Studio throws this error:
"The feature source is invalid. reason: an exception occurred in FDO component. Failed to de-serialize the schema mappings from configuration."
I'm sending a configuration file, maybe someone can see "from the first look" where is problem. Also, I have attached tfw file from one of my rasters.
Thanks a lot, I'm really stucked.
PS - I'm from outised of US and I have different decimal separator. Maybe this means someone somthing.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071205/709d94ac/attachment.bin
