[mapguide-users] how to create an mgp file?
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Dec 6 02:46:04 EST 2007
Its not clear to me, what you want to do.
You can create MGP packages from an entire folder.
You can modify the MGP file as a Zip file afterwards.
AFAIK, there is no documentation for the MGP format.
The format is quite simple, the MGP is a Zip file, which contains all
the data, SDF and Xml.
There is a manifest file in the MGP, which contains operations executed
agains the server.
These operations execute the actual data storage of either SDF or Xml data.
The SDF files are usually stored as "ResourceData" on a FeatureSource (Xml).
Regards, Kenneth, GEOGRAF A/S
Parvatha skrev:
> In site administrator we can create mgp files but for that we need to have
> xml files in a folder which has got the details of the sdf data. I want to
> know how to create those xml files and where to keep the sdf data and what
> is the format?
> zspitzer wrote:
>> you can create a mgp via the mapguide site administrator
>> On Dec 6, 2007 3:35 PM, Parvatha <kpeswari at indiainfo.com> wrote:
>>> Hi
>>>  can anybody tell me how to create an mgp file? when i download the
>>> sample
>>> (sheboygan) data for mapguide opensource 1.2 its a zip file. When i unzip
>>> that i could see all xml files. Using mapadmin if i load that mgp then in
>>> the "library" folder in local there is a "data" folder in that all sdf
>>> files
>>> are loaded. I dont understand from where it is getting loaded
>>> dynamically.
>>> If this is the way then how to create xml file for my own sdf data to
>>> make
>>> an mgp? and where to keep the sdf? bcoz in xml file only the sdf name has
>>> given and the path is not given. Can anybody please calrify my doubt?
>>> Regards
>>> Parvatha
>>> View this message in context:
>>> http://www.nabble.com/how-to-create-an-mgp-file--tf4953979s16610.html#a14186172
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071206/5daf1b90/attachment.html
