[mapguide-users] how to create an mgp file?
Parvatha
kpeswari at indiainfo.com
Tue Dec 11 07:09:25 EST 2007
I am unable to load my SDF data using web studio; So i am trying someother
way. If I can convert my data to mgp format then there is no need to load
the sdf i think. I need to load only the mgp using mapadmin. This will also
solve my problem. I have sdf but i dont know how to create xml files. So
that if I have xml and sdf then i can make mgp. This is what my problem.
Kenneth, GEOGRAF A/S wrote:
> Its not clear to me, what you want to do.
> You can create MGP packages from an entire folder.
> You can modify the MGP file as a Zip file afterwards.
> AFAIK, there is no documentation for the MGP format.
> The format is quite simple, the MGP is a Zip file, which contains all
> the data, SDF and Xml.
> There is a manifest file in the MGP, which contains operations executed
> agains the server.
> These operations execute the actual data storage of either SDF or Xml
> data.
> The SDF files are usually stored as "ResourceData" on a FeatureSource
> (Xml).
> Regards, Kenneth, GEOGRAF A/S
> Parvatha skrev:
>> In site administrator we can create mgp files but for that we need to
>> have
>> xml files in a folder which has got the details of the sdf data. I want
>> to
>> know how to create those xml files and where to keep the sdf data and
>> what
>> is the format?
>> zspitzer wrote:
>>> you can create a mgp via the mapguide site administrator
>>> On Dec 6, 2007 3:35 PM, Parvatha <kpeswari at indiainfo.com> wrote:
>>>> Hi
>>>> can anybody tell me how to create an mgp file? when i download the
>>>> sample
>>>> (sheboygan) data for mapguide opensource 1.2 its a zip file. When i
>>>> unzip
>>>> that i could see all xml files. Using mapadmin if i load that mgp then
>>>> in
>>>> the "library" folder in local there is a "data" folder in that all sdf
>>>> files
>>>> are loaded. I dont understand from where it is getting loaded
>>>> dynamically.
>>>> If this is the way then how to create xml file for my own sdf data to
>>>> make
>>>> an mgp? and where to keep the sdf? bcoz in xml file only the sdf name
>>>> has
>>>> given and the path is not given. Can anybody please calrify my doubt?
>>>> Regards
>>>> Parvatha
>>>> View this message in context:
>>>> http://www.nabble.com/how-to-create-an-mgp-file--tf4953979s16610.html#a14186172
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer -
>>> http://zacster.blogspot.com (My Blog)
>>> +61 405 847 168
View this message in context: http://www.nabble.com/how-to-create-an-mgp-file--tp14186172s16610p14272461.html
