[mapguide-users] how to create an mgp file?
Zac Spitzer
zac.spitzer at gmail.com
Tue Dec 11 18:19:46 EST 2007
it's good when two people provide similar answers :)
brainstorming on this, if webstudio is not going to be up to the task
generally, it
would be good if there was page under mapagent which allows a SDF on the
server
to be added to the repository as a managed feature source
z
On Dec 11, 2007 11:20 PM, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
> The only approach I can think of, is to study one of the existing demo
> packages.
> Study the Xml to see how it is constructed, and create a copy.
> You will likely want to use MapGuide Studio from Autodesk at some point.
> Alternatively, if your only objective is to upload an SDF file, you can
> try out my MapStudio project (which is very alpha at the moment).
> Third option for access to SDF, is to get a FeatureSource xml file, and
> modify the file path.
> You can read/write the FeatureSource Xml from either the API or
> http://localhost/mapguide/mapagent/mapagent.fcgi
> Regards, Kenneth, GEOGRAF A/S
> Parvatha skrev:
> I am unable to load my SDF data using web studio; So i am trying someother
> way. If I can convert my data to mgp format then there is no need to load
> the sdf i think. I need to load only the mgp using mapadmin. This will also
> solve my problem. I have sdf but i dont know how to create xml files. So
> that if I have xml and sdf then i can make mgp. This is what my problem.
> Kenneth, GEOGRAF A/S wrote:
> Its not clear to me, what you want to do.
> You can create MGP packages from an entire folder.
> You can modify the MGP file as a Zip file afterwards.
> AFAIK, there is no documentation for the MGP format.
> The format is quite simple, the MGP is a Zip file, which contains all
> the data, SDF and Xml.
> There is a manifest file in the MGP, which contains operations executed
> agains the server.
> These operations execute the actual data storage of either SDF or Xml
> data.
> The SDF files are usually stored as "ResourceData" on a FeatureSource
> (Xml).
> Parvatha skrev:
> In site administrator we can create mgp files but for that we need to
> have
> xml files in a folder which has got the details of the sdf data. I want
> to
> know how to create those xml files and where to keep the sdf data and
> what
> is the format?
> zspitzer wrote:
> you can create a mgp via the mapguide site administrator
> On Dec 6, 2007 3:35 PM, Parvatha <kpeswari at indiainfo.com> <kpeswari at indiainfo.com> wrote:
> Hi
> can anybody tell me how to create an mgp file? when i download the
> sample
> (sheboygan) data for mapguide opensource 1.2 its a zip file. When i
> unzip
> that i could see all xml files. Using mapadmin if i load that mgp then
> in
> the "library" folder in local there is a "data" folder in that all sdf
> files
> are loaded. I dont understand from where it is getting loaded
> dynamically.
> If this is the way then how to create xml file for my own sdf data to
> make
> an mgp? and where to keep the sdf? bcoz in xml file only the sdf name
> has
> given and the path is not given. Can anybody please calrify my doubt?
> Regards
> Parvatha
> View this message in context:http://www.nabble.com/how-to-create-an-mgp-file--tf4953979s16610.html#a14186172
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071212/62262362/attachment.html
