[mapguide-users] Problem with login on Map guide 1.2
sRiE
ryne_79 at yahoo.com
Wed Dec 12 10:48:27 EST 2007
----- Original Message ----
From: "mapguide-users-request at lists.osgeo.org" <mapguide-users-request at lists.osgeo.org>
To: mapguide-users at lists.osgeo.org
Sent: Wednesday, December 12, 2007 1:00:12 AM
Subject: mapguide-users Digest, Vol 12, Issue 11
Send mapguide-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/mapguide-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
mapguide-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of mapguide-users digest..."
Today's Topics:
1. RE: RFC43 - FDO maps some database types like an Oracle
NUMBER(38,0) to an Fdo decimal. (Trevor Wekel)
2. Re: RFC43 - FDO maps some database types like an Oracle
NUMBER(38, 0) to an Fdo decimal. (Ryan Northcott)
3. Re: King.Oracle and Autodesk Oracle provider, line selection
problem (Zac Spitzer)
4. Re: Using X,Y from Oracle (Zac Spitzer)
5. Re: Using X,Y from Oracle (Andrew DeMerchant)
6. Re: Tomcat error on Release 2.0.0 Beta 1 (eespares)
7. MGOS and rastet support (MaciekS)
8. Re: King.Oracle and Autodesk Oracle provider, line selection
problem (Kenneth, GEOGRAF A/S)
9. Re: MGOS and rastet support (Kenneth, GEOGRAF A/S)
10. Re: Problem with login on Map guide 1.2 (uXuf)
11. Re: how to create an mgp file? (Parvatha)
12. Re: how to create an mgp file? (Zac Spitzer)
13. Re: how to create an mgp file? (Kenneth, GEOGRAF A/S)
14. Re: Problem with login on Map guide 1.2 (Kenneth, GEOGRAF A/S)
15. Re: Tooltip/mouseover problem (btenbroeck)
16. MG 2.0 beta1 on Ubuntu 7.10 not showing map (Mange)
17. Re: MG 2.0 beta1 on Ubuntu 7.10 not showing map (Mange)
Message: 1
Date: Mon, 10 Dec 2007 09:26:58 -0800
Subject: RE: [mapguide-users] RFC43 - FDO maps some database types
like an Oracle NUMBER(38,0) to an Fdo decimal.
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Message-ID:
<D8305E7409B5DB46A9D6219E54E1CF1A177409CD6C at ADSK-NAMSG-01.MGDADSK.autodesk.com>
Content-Type: text/plain; charset="us-ascii"
Hi Bruno,
I am not an FDO expert. You may want to post this question to the FDO users or FDO internals list.
Thanks,
Trevor
-----Original Message-----
Sent: Monday, December 10, 2007 12:18 AM
Subject: [mapguide-users] RFC43 - FDO maps some database types like an Oracle NUMBER(38,0) to an Fdo decimal.
Should FDO maps NUMBER(18,0) to int32 or int63 instead?
Bruno Scott
View this message in context: http://www.nabble.com/RFC43---FDO-maps-some-database-types-like-an-Oracle-NUMBER%2838%2C0%29-to-an-Fdo-decimal.-tp14248311s16610p14248311.html
Message: 2
Date: Mon, 10 Dec 2007 12:39:57 -0500
Subject: Re: [mapguide-users] RFC43 - FDO maps some database types
like an Oracle NUMBER(38, 0) to an Fdo decimal.
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Message-ID:
<d45479700712100939u1b6181c3ra8afc9eeca6aa95 at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Number(18,0) are usually Long / Int64's
On Dec 10, 2007 12:26 PM, Trevor Wekel <trevor.wekel at autodesk.com> wrote:
> Hi Bruno,
> Thanks,
> Trevor
> From: Bruno Scott [mailto:bscott at geomapgis.com]
> Bruno Scott
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071210/698d5cb6/attachment-0001.html
Message: 3
Date: Tue, 11 Dec 2007 10:19:55 +1100
Subject: Re: [mapguide-users] King.Oracle and Autodesk Oracle
provider, line selection problem
Message-ID:
<7a85053e0712101519v52a58b36pd6c0e336aff7a697 at mail.gmail.com>
just a guess, http://trac.osgeo.org/mapguide/wiki/MapGuideRfc43 ??
On Dec 11, 2007 1:32 AM, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
> Having tested the King.Oracle provider, I noticed some lines were not
> selectable, even though other lines from the same layer were.
> I then tried the Autodesk provider, and the behavior was exactly the same.
> Has anyone seen anything like this, or have a good guess?
> I also noticed that both providers report that there are points in the
> layers, even though selecting the geometry type manually reveals that
> there is not.
> Any thoughts on that?
> Regards, Kenneth, GEOGRAF A/S
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071211/38033840/attachment-0001.html
Message: 4
Date: Tue, 11 Dec 2007 10:21:53 +1100
Subject: Re: [mapguide-users] Using X,Y from Oracle
Message-ID:
<7a85053e0712101521w77d91717yb56cd46c0d0f76a9 at mail.gmail.com>
Skipped content of type multipart/alternative-------------- next part --------------
Name: not available
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071211/1cf75c81/attachment-0001.gif
Message: 5
Date: Mon, 10 Dec 2007 21:27:45 -0400
From: Andrew DeMerchant <andrew.demerchant at gemtec.ca>
Message-ID: <475DE791.4060207 at gemtec.ca>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Well, in any case the FDO provider doesn't seem to like them either.
Just throwing that info out there in case it was of use to anyone - like
I said, I don't know Oracle.
Zac Spitzer wrote:
> It's mostly MS databases which allows spaces, Oracle definately doesn't
> On Dec 11, 2007 2:57 AM, Andrew DeMerchant
> <andrew.demerchant at gemtec.ca <mailto:andrew.demerchant at gemtec.ca>> wrote:
> I have no experience with Oracle, but I can tell you that in order
> to produce points from x and y data using the ODBC FDO, you need
> to have the x and y fields as doubles, rather than single or
> integers. You also can't have any spaces in the names of ANY
> fields in tables you're using....same goes for table names. Using
> that method, I can get my points to show up fine - using either
> Access or SQL Server (both via OBDC).
> Andrew
> Brad Nesom wrote:
>> I haven't seen the new MG's capability to produce points. I know that it was
>> a capability in MG6.5. I'm sure someone else will have the answer.
>> Brad
>> From: mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org>
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
>> GEOGRAF A/S
>> Sent: Monday, December 10, 2007 8:37 AM
>> Subject: [mapguide-users] Using X,Y from Oracle
>> I have tried to produce points from an Oracle database with only x and y
>> data, no SDO geometry.
>> Using King.Oracle these tables do not appear, using the Autodesk
>> provider shows these, but does not allow for mapping with X/Y.
>> I then tried to load the Oracle as an ODBC connection.
>> After waiting approximately 10 minutes after pressing save, the
>> FeatureSource is saved.
>> After this, there are no tables listed in the FeatureSource.
>> Can I fix this somehow, or is it better to convert the columns to SDO?
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> Zac Spitzer -
> +61 405 847 168
Message: 6
Date: Mon, 10 Dec 2007 22:19:48 -0800 (PST)
Subject: Re: [mapguide-users] Tomcat error on Release 2.0.0 Beta 1
Message-ID: <14268499.post at talk.nabble.com>
Content-Type: text/plain; charset=us-ascii
Mbonnet,
Thanks for your inputs, it works for me also.
Cheers,
Eric
Mbonnet wrote:
> i 've just fixed out. in the conf directory of the tomcat, create a
> directory called
> Catalina and in this a subdirectory called locahost and put the
> mapguide.xml (in the conf directory) in it.
> and it works for me.
View this message in context: http://www.nabble.com/Tomcat-error-on-Release-2.0.0-Beta-1-tp14206509s16610p14268499.html
Message: 7
Date: Tue, 11 Dec 2007 01:04:41 -0800 (PST)
Subject: [mapguide-users] MGOS and rastet support
Message-ID: <14270233.post at talk.nabble.com>
Hi all.
Does MapGuide Open Source provide raster (ortophotomaps) support?
Maciek
View this message in context: http://www.nabble.com/MGOS-and-rastet-support-tp14270233s16610p14270233.html
Message: 8
Date: Tue, 11 Dec 2007 13:01:36 +0100
Message-ID: <475E7C20.10309 at geograf.dk>
Not exactly.
If I had one layer visible, and tried to select all lines, only some
would be selected.
I will have a look at the data definitions for the tables, and see if
something is odd.
> On Dec 11, 2007 1:32 AM, Kenneth, GEOGRAF A/S < ks at geograf.dk
> the same.
> the
> there is not.
> <http://lists.osgeo.org/mailman/listinfo/mapguide-users>
> Zac Spitzer -
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071211/6cddf541/attachment-0001.html
Message: 9
Date: Tue, 11 Dec 2007 13:03:03 +0100
Subject: Re: [mapguide-users] MGOS and rastet support
Message-ID: <475E7C77.1040705 at geograf.dk>
Yes.
It supports them with the GDal provider.
I have tested ECW, and others report success with Mr.Sid files.
MaciekS skrev:
> Hi all.
> Maciek
Message: 10
Date: Tue, 11 Dec 2007 04:03:41 -0800 (PST)
Subject: Re: [mapguide-users] Problem with login on Map guide 1.2
Message-ID: <14272458.post at talk.nabble.com>
Can you think of something that you might have done exploring it as the
possible cause?
It should work fine if everything was untouched.
uXuf
Klemen Sorcnik wrote:
> Hello,
> i have problems with login on map guide open source 1.2. When i installed
> it worked fine, but next day i want to login again it says Authentication
> failed.
> I havent changed anything (USER: Administrator PWD: admin).
> I had no problems with login in map guide 1.2 RC2. Can anyone help me?
> Klemen s.
View this message in context: http://www.nabble.com/Problem-with-login-on-Map-guide-1.2-tp14248241s16610p14272458.html
Message: 11
Date: Tue, 11 Dec 2007 04:09:25 -0800 (PST)
Subject: Re: [mapguide-users] how to create an mgp file?
Message-ID: <14272461.post at talk.nabble.com>
I am unable to load my SDF data using web studio; So i am trying someother
way. If I can convert my data to mgp format then there is no need to load
the sdf i think. I need to load only the mgp using mapadmin. This will also
solve my problem. I have sdf but i dont know how to create xml files. So
that if I have xml and sdf then i can make mgp. This is what my problem.
Kenneth, GEOGRAF A/S wrote:
> Its not clear to me, what you want to do.
> You can create MGP packages from an entire folder.
> You can modify the MGP file as a Zip file afterwards.
> AFAIK, there is no documentation for the MGP format.
> The format is quite simple, the MGP is a Zip file, which contains all
> the data, SDF and Xml.
> There is a manifest file in the MGP, which contains operations executed
> agains the server.
> These operations execute the actual data storage of either SDF or Xml
> data.
> The SDF files are usually stored as "ResourceData" on a FeatureSource
> (Xml).
> Parvatha skrev:
>> In site administrator we can create mgp files but for that we need to
>> have
>> xml files in a folder which has got the details of the sdf data. I want
>> to
>> know how to create those xml files and where to keep the sdf data and
>> what
>> is the format?
>> zspitzer wrote:
>>> you can create a mgp via the mapguide site administrator
>>> On Dec 6, 2007 3:35 PM, Parvatha <kpeswari at indiainfo.com> wrote:
>>>> Hi
>>>> can anybody tell me how to create an mgp file? when i download the
>>>> sample
>>>> (sheboygan) data for mapguide opensource 1.2 its a zip file. When i
>>>> unzip
>>>> that i could see all xml files. Using mapadmin if i load that mgp then
>>>> in
>>>> the "library" folder in local there is a "data" folder in that all sdf
>>>> files
>>>> are loaded. I dont understand from where it is getting loaded
>>>> dynamically.
>>>> If this is the way then how to create xml file for my own sdf data to
>>>> make
>>>> an mgp? and where to keep the sdf? bcoz in xml file only the sdf name
>>>> has
>>>> given and the path is not given. Can anybody please calrify my doubt?
>>>> Regards
>>>> Parvatha
>>>> http://www.nabble.com/how-to-create-an-mgp-file--tf4953979s16610.html#a14186172
>>>> _______________________________________________
>>> Zac Spitzer -
>>> +61 405 847 168
View this message in context: http://www.nabble.com/how-to-create-an-mgp-file--tp14186172s16610p14272461.html
Message: 12
Date: Tue, 11 Dec 2007 23:18:44 +1100
Message-ID:
<7a85053e0712110418p6a7935b3y14a8f48fc2cdb23f at mail.gmail.com>
now it's clearer what you are trying to do!
you can use an unmanaged feature source, which means you reference a sdf
file on
the server which lives outside the repository.. there for you bypass
webstudio...
the xml looks like, where C is a directory on your server
<?xml version="1.0" encoding="ISO-8859-1"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="
FeatureSource-1.0.0.xsd">
<Provider>OSGeo.SDF</Provider>
<Parameter>
<Name>File</Name>
<Value>c:\data\DEMO~GEOMETRY.sdf</Value>
</Parameter>
<Parameter>
<Name>ReadOnly</Name>
<Value>TRUE</Value>
</Parameter>
</FeatureSource>
Otherwise you can use the API in .NET, PHP or Java to upload into the
repository
z
> also
> > agains the server.
> > data.
> > (Xml).
> >> have
> >> to
> >> what
> >> is the format?
> >>>> Hi
> >>>> sample
> >>>> unzip
> then
> >>>> in
> sdf
> >>>> files
> >>>> dynamically.
> >>>> make
> >>>> has
> >>>> Regards
> >>>> Parvatha
> >>> Zac Spitzer -
> >>> +61 405 847 168
Zac Spitzer -
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071211/bd054a13/attachment-0001.html
Message: 13
Date: Tue, 11 Dec 2007 13:20:54 +0100
Message-ID: <475E80A6.3020606 at geograf.dk>
The only approach I can think of, is to study one of the existing demo
packages.
Study the Xml to see how it is constructed, and create a copy.
You will likely want to use MapGuide Studio from Autodesk at some point.
Alternatively, if your only objective is to upload an SDF file, you can
try out my MapStudio project (which is very alpha at the moment).
Third option for access to SDF, is to get a FeatureSource xml file, and
modify the file path.
You can read/write the FeatureSource Xml from either the API or
http://localhost/mapguide/mapagent/mapagent.fcgi
>> agains the server.
>> data.
>> (Xml).
>>> have
>>> to
>>> what
>>> is the format?
>>>>> Hi
>>>>> sample
>>>>> unzip
>>>>> in
>>>>> files
>>>>> dynamically.
>>>>> make
>>>>> has
>>>>> Regards
>>>>> Parvatha
>>>> Zac Spitzer -
>>>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071211/e320f57d/attachment-0001.html
Message: 14
Date: Tue, 11 Dec 2007 13:26:28 +0100
Message-ID: <475E81F4.40404 at geograf.dk>
I have the same problem like you but I'm using Mapguide 1.2.0rc2. I got this error msg "unable to connect to mapguide server. Please ensure that the server process is running and firewall rules have been set correctly" when trying login to MGS and this "Authentication failed. Please enter a valid username and password." when trying login in Mapguide Site Admin. Try to restart mapguide server, but I got this msg "could not stop the mapguide server v1.2 service on local computer. Error 1053: The service did not respond to the start or control request in a timely fashion.".
Some steps that I already take:
-disable firewall for mgserver.exe.
-repair mapguide server
-uninstall mapguide server/web ext
-and install it again.
and yet, the same problem...I don't know what else to check?can anyone help?
Thanks & Regards,
Srie Azrina
Do you have login trouble with the MapAdmin, WebStudio or MapGuide Studio?
If the problem is with them all, you might consider a reinstall, as that
will clear the password.
> possible cause?
> uXuf
>> Hello,
>> failed.
>> Klemen s.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071211/fe2468a1/attachment-0001.html
Message: 15
Date: Tue, 11 Dec 2007 05:05:27 -0800 (PST)
Subject: Re: [mapguide-users] Tooltip/mouseover problem
Message-ID: <14273525.post at talk.nabble.com>
Hi Marius.
Did you ever get a response/resolution on this? I'm seeing the same
behavior.
Marius_360 wrote:
> We are currently creating a website on mapguide open source 1.2, with the
> latest FDO King providers as we are working with oracle spatial data. The
> database is Oracle XE. Now when we create a tooltip/mouseover on a layer
> (all the attributes are stored within the spatial tables), it starts to
> display Chinese characters and some other strange characters mixed with
> some normal ones. This only happens when more than one column is used in
> the mouseover.
> Marius
View this message in context: http://www.nabble.com/Tooltip-mouseover-problem-tp13604647s16610p14273525.html
Message: 16
Date: Tue, 11 Dec 2007 05:59:23 -0800 (PST)
Subject: [mapguide-users] MG 2.0 beta1 on Ubuntu 7.10 not showing map
Message-ID: <14274495.post at talk.nabble.com>
I've installed according to the explanation in the wiki section and also
installed the Sheboygan demo + an internal project based on SHP data.
Problem with both packages is that when viewing them in either the ajax
viewer, fusion and phpviewer the map is not rendered (see attached image). I
have checked the logs under /usr/local/mapguideopensource/server/Logs and
loading the packages
I suspect that fdo-3.3 is not working as expected. Anyone have some ideas?
Is there a way to trace or alter the errorlevel on mg?
http://www.nabble.com/file/p14274495/mapguide%2Bsheboygan%2Bwithout%2Bmap.png
Thanks,
Mange
View this message in context: http://www.nabble.com/MG-2.0-beta1-on-Ubuntu-7.10-not-showing-map-tp14274495s16610p14274495.html
Message: 17
Date: Tue, 11 Dec 2007 06:49:42 -0800 (PST)
Subject: Re: [mapguide-users] MG 2.0 beta1 on Ubuntu 7.10 not showing
map
Message-ID: <14275439.post at talk.nabble.com>
I may also mention that when trying the API Rendering --> GetMapImage and
point to en existing library. The result is an empty (blank) png image.
/Mange
View this message in context: http://www.nabble.com/MG-2.0-beta1-on-Ubuntu-7.10-not-showing-map-tp14274495s16610p14275439.html
End of mapguide-users Digest, Vol 12, Issue 11
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
