[mapguide-users] Problem with login on Map guide 1.2
sRiE ryne_79 at yahoo.com
Wed Dec 12 21:20:34 EST 2007
I have the same problem like you but I'm using Mapguide 1.2.0rc2. I got this error msg "unable to connect to mapguide server. Please ensure that the server process is running and firewall rules have been set correctly" when trying login to MGS and this "Authentication failed. Please enter a valid username and password." when trying login in Mapguide Site Admin. Try to restart mapguide server, but I got this msg "could not stop the mapguide server v1.2 service on local computer. Error 1053: The service did not respond to the start or control request in a timely fashion.".
Steps that I've taken:
-disable firewall for mgserver.exe.
-repair mapguide server
-uninstall mapguide server/web ext
-and install it again.
and yet, the same problem...I don't know what else to check?can anyone help?
Thanks & Regards,
Srie Azrina
>Do you have login trouble with the MapAdmin, WebStudio or MapGuide Studio?
>If the problem is with them all, you might consider a reinstall, as that
>will clear the password.
>Regards, Kenneth, GEOGRAF A/S
uXuf skrev:
> Can you think of something that you might have done exploring it as the
> possible cause?
> It should work fine if everything was untouched.
> uXuf
> Klemen Sorcnik wrote:
>> Hello,
>> i have problems with login on map guide open source 1.2. When i installed
>> it worked fine, but next day i want to login again it says Authentication
>> failed.
>> I havent changed anything (USER: Administrator PWD: admin).
>> I had no problems with login in map guide 1.2 RC2. Can anyone  help me?
>> Klemen s.
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
