[mapguide-users] Loading a large SHP file
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Dec 13 05:55:12 EST 2007
You can try to use it as a "unmanaged resource".
I have not used the SHP much, but it should be similar to the SDF procedure.
You can create a SHP featuresource, using a small file.
Then edit the FeatureSource xml, and modify the path to point at your
SHP file.
You can point the path to your SHP file, outside MapGuide.
This approach has pros and cons.
Pros include ability to backup the file easily, and shared access.
Cons are about the same, depending on what you think is great.
You should be able to find examples for the SDF procedure, and customize
it for SHP.
Regards, Kenneth, GEOGRAF A/S
azpublic skrev:
> HI all,
> I’m trying to load a relatively large SHP file (140MB) using Studio
> 2007. Each time I try loading the file using a load procedure, I get
> an alert popup asking me to package the file using the “File > Package
> Spatial Data …” menu. I tried loading the SHP directly using the
> “Resources Button” without success as Studio just hangs and never
> comes back to life.
> The same think happens when I try using the suggested “Package Spatial
> Data” functionality. If I look in the folder where the original SHP is
> located I can see a file with the *.mgp extension with 0kb in size.
> Also during the packaging procedure an *.idx file is created in the
> source folder and its size grows regularly up to a certain point.
> After a while nothing happens and Studio just keeps on hanging…
> What can I do to load my file into the MGOS Library ?
> Thanks
> Internal Virus Database is out-of-date.
> Checked by AVG Free Edition.
> Version: 7.5.503 / Virus Database: 269.16.13 - Release Date:
> 02.12.2007 00:00
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071213/c17fb811/attachment.html
