SV: [mapguide-users] Sheboygan problems
Martin Burrows
martin.burrows at geosol.se
Fri Dec 14 05:05:55 EST 2007
Hi Solomon,
The OS sometimes understands that the mgp-file is a zip-file and changes the
extension during download.
Manually change the filename to sheboygan.mgp and you should be fine.
(Make sure that the path is: C\Program
files\MapGuideOpenSource\Server\Packages\Sheboygan.mgp.)
Best regards,
Martin
_____
Från: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] För Solomon Bhunu
Skickat: den 14 december 2007 10:56
Till: MapGuide Users Mail List
Ämne: RE: [mapguide-users] Sheboygan problems
I have downloaded the sheboygan.mgp file below, but it downloads as a zip
file. If you have a copy which is not in zipped format then kindly forward
it. thanks
Samples
Use these links to get a sample application that demonstrates some of the
functionality of MapGuide.
* phpviewersample-1.1.zip
<http://download.osgeo.org/mapguide/releases/1.1.0/samples/phpviewersample-1
.1.zip> [120,779 bytes]
md5: 1d9e243e1a11333d87e390d70b4616db
Sample application written in PHP that demonstrates how to use the MapGuide
APIs.
* dotnetviewersample-1.1.zip
<http://download.osgeo.org/mapguide/releases/1.1.0/samples/dotnetviewersampl
e-1.1.zip> [119,761 bytes]
md5: 8c13b5f61ba3807aaabb4335bb7b3367
Sample application written in ASP.NET that demonstrates how to use the
MapGuide APIs.
* javaviewersample-1.1.zip
<http://download.osgeo.org/mapguide/releases/1.1.0/samples/javaviewersample-
1.1.zip> [116,500 bytes]
md5: bfb590d8b5dca8118a06d3bb8f46f2dd
Sample application written in JSP that demonstrates how to use the MapGuide
APIs.
* Sheboygan.mgp
<http://download.osgeo.org/mapguide/releases/1.0.0/samples/Sheboygan.mgp>
[13,870,308 bytes]
md5: a712dbba31b9b34f1fd3de416e016d43
Sample package of data, layer, map, and web layout resources for use with
the sample application.
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Konstantinos
Vassiliadis
Sent: 14 December 2007 11:40 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Sheboygan problems
Why don't you download it from https://mapguide.osgeo.org/download1.1.0.html
and just get the .mgp file, not zipped?
On Dec 14, 2007 11:23 AM, Solomon Bhunu < Solomon.Bhunu at capetown.gov.za>
wrote:
Yes, I have deposited the file into the right folder as a zip file before
changing the name to a mgp file. However, when I double click on the file,
the path indicates this: C\Program
files\MapGuideOpenSource\Server\Packages\Sheboygan.mgp.zip
_____
Vassiliadis
Sent: 14 December 2007 11:16 AM
Have you browsed to the proper folder on your server to locate the file?
Kostas
On Dec 14, 2007 11:13 AM, Solomon Bhunu <Solomon.Bhunu at capetown.gov.za >
wrote:
Could someone assist?
I have tried to load the sheboygan file without success. I have changed
the file name from sheboygan.zip to sheboygan.mgp and put it into the
folder C:\program Files\MapGuideOpenSource\Server\Packages but still when
I go to MapGuide Site Administrator and click on Manage packages, "No
packages found' message comes up.
thanks
NOTE: This e-mail (including attachments) is subject to the restrictions,
qualifications and disclaimers ("disclaimer") published at:
http://www.capetown.gov.za/disclaimer/site/. Please read the disclaimer
before opening any attachment or taking any other action in terms of this
e-mail. If you cannot access the disclaimer, kindly send an email to
disclaimer at capetown.gov.za and a copy will be provided to you. By relying of
this e-mail or opening any attachment you agree to be bound by the
provisions of the disclaimer.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071214/f1be9567/attachment.html
