[mapguide-users] Sheboygan problems
Solomon Bhunu Solomon.Bhunu at capetown.gov.za
Fri Dec 14 05:13:17 EST 2007
Thanks to all for the assistance. It worked.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin Burrows
Sent: 14 December 2007 12:06 PM
To: 'MapGuide Users Mail List'
Subject: SV: [mapguide-users] Sheboygan problems
Hi Solomon,
The OS sometimes understands that the mgp-file is a zip-file and changes the extension during download.
Manually change the filename to sheboygan.mgp and you should be fine.
(Make sure that the path is:  "C\Program files\MapGuideOpenSource\Server\Packages\Sheboygan.mgp.")
Best regards,
Martin
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Solomon Bhunu
Skickat: den 14 december 2007 10:56
Till: MapGuide Users Mail List
Ämne: RE: [mapguide-users] Sheboygan problems
I have downloaded the sheboygan.mgp file below, but it downloads as a zip file. If you have a copy which is not in zipped format then kindly  forward it. thanks
Samples
Use these links to get a sample application that demonstrates some of the functionality of MapGuide.
*	phpviewersample-1.1.zip <http://download.osgeo.org/mapguide/releases/1.1.0/samples/phpviewersample-1.1.zip>  [120,779 bytes]
	md5: 1d9e243e1a11333d87e390d70b4616db
	Sample application written in PHP that demonstrates how to use the MapGuide APIs.
*	dotnetviewersample-1.1.zip <http://download.osgeo.org/mapguide/releases/1.1.0/samples/dotnetviewersample-1.1.zip>  [119,761 bytes]
	md5: 8c13b5f61ba3807aaabb4335bb7b3367
	Sample application written in ASP.NET that demonstrates how to use the MapGuide APIs.
*	javaviewersample-1.1.zip <http://download.osgeo.org/mapguide/releases/1.1.0/samples/javaviewersample-1.1.zip>  [116,500 bytes]
	md5: bfb590d8b5dca8118a06d3bb8f46f2dd
	Sample application written in JSP that demonstrates how to use the MapGuide APIs.
*	Sheboygan.mgp <http://download.osgeo.org/mapguide/releases/1.0.0/samples/Sheboygan.mgp>  [13,870,308 bytes]
	md5: a712dbba31b9b34f1fd3de416e016d43
	Sample package of data, layer, map, and web layout resources for use with the sample application.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Konstantinos Vassiliadis
Sent: 14 December 2007 11:40 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Sheboygan problems
Why don't you download it from https://mapguide.osgeo.org/download1.1.0.html and just get the .mgp file, not zipped?
On Dec 14, 2007 11:23 AM, Solomon Bhunu < Solomon.Bhunu at capetown.gov.za> wrote:
Yes, I have deposited the file into the right folder as a zip file before changing the name to a mgp file. However, when I double click on the file, the path indicates this:  C\Program files\MapGuideOpenSource\Server\Packages\Sheboygan.mgp.zip
Sent: 14 December 2007 11:16 AM
Have you browsed to the proper folder on your server to locate the file?
Kostas
On Dec 14, 2007 11:13 AM, Solomon Bhunu <Solomon.Bhunu at capetown.gov.za > wrote:
Could someone assist?
I  have tried  to load the sheboygan file without success. I have changed the file name from sheboygan.zip to sheboygan.mgp  and put it into the folder C:\program Files\MapGuideOpenSource\Server\Packages   but still when I go to MapGuide Site Administrator and click on Manage packages,  "No packages found' message comes up.
thanks
NOTE: This e-mail (including attachments) is subject to the restrictions, qualifications and disclaimers ("disclaimer") published at: http://www.capetown.gov.za/disclaimer/site/. Please read the disclaimer before opening any attachment or taking any other action in terms of this e-mail. If you cannot access the disclaimer, kindly send an email to disclaimer at capetown.gov.za and a copy will be provided to you. By relying of this e-mail or opening any attachment you agree to be bound by the provisions of the disclaimer.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071214/c2f92d2d/attachment.html
