[mapguide-users] Fusion... getting started.
Jason Birch
Jason.Birch at nanaimo.ca
Tue Dec 18 15:19:26 EST 2007
Hi all,
I just noticed that someone uploaded some documentation on Fusion :)
http://download.osgeo.org/mapguide/releases/2.0.0-beta2/doc/
These still look a bit "beta" (ie. incomplete), but there is some good
information in there. I would suggest ignoring the "Installing and
Configuring" doc. Start with "Introduction" (briefly), go on to
"Generic Web Mapping Application Components", then "Widget Concepts",
and finally "Create A Basic Web Mapping Application".
There is also a new template called "learn" in Beta2. This template not
exactly basic (it looks a _lot_ like the familiar AJAX viewer) but is
well commented. This appears to be featured in the "Create a Basic..."
documentation; perhaps the link will be tighter once the documentation
is complete. It is a good starting point for beginning to understand
some of the more involved Jx layout capabilities, advanced widgets, etc.
Here's a hint by way of Chris Claydon... If you are trying to figure
out the parameters to a specific widget, they should be documented in
XML files in this folder:
C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\widgets\widge
tinfo
If you are starting down the path of figuring out how Fusion works, you
might also find a snippet that I recently put together useful:
http://trac.osgeo.org/mapguide/wiki/CodeSamples/Fusion/SuperSimple
( or http://tinyurl.com/26mmh8 )
Let me know if you try this out and it doesn't work :) I did just test
it under Beta 2, but you know how those gremlins work...
You don't need anything more complicated than a text editor for any of
this. Of course... the hope is that eventually there will be tools that
make this a lot easier.
Jason
