[mapguide-users] Trusted Sites
Chris Tallman
ctallman at innomap.com
Thu Dec 20 07:49:05 EST 2007
Looks like we were chasing the same thing that has been an issue for awhile now. I found posts talking about the gap when measuring, digitizing, and the selection tool, selecting the wrong location. So I'm not sure what happens when IE asks to enable the MSXML 5.0 add-on but the gap doesn't appear when that pop-up bar comes up, whether the properties pane in on or off.
I tried the fix proposed by Maciej Skórczewski it didn't seem to have any affect. So far the only thing I found that fixes it correctly on the initial load is having the properties pane on.
Here is a link to Maciej Skórczewski post:
http://www.nabble.com/Re%3A-Map-Viewer-Gap-p10052754s16610.html
The second change is the one I tried and it didn't change the gap.
Chris
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Tallman
Sent: Thursday, December 20, 2007 7:21 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Trusted Sites
I see the same gap at the top of the map. The gap is there when the properties pane is turned off, and there is no gap when the properties pane is on. I also see if you resize the map the gap goes away and everything is fine.
So its got to be a bug some place in the AJAX Viewer. I think I remember some posts about this gap a week ago or more. Have to search the old posts.
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gunter Becker
Sent: Thursday, December 20, 2007 3:57 AM
To: mapguide-users at lists.osgeo.org
Hi Chris,
I've made yesterday exactly the same experience like you but didn't realise that the tooltip shows up when moving the mouse cursor north of the object.
I thought I've done something wrong but now think it's a bug in AJAX Viewer.
When you have a colored background (I mean for eyample a polygon layer behind your symbol layer) you can see that there is a gap between the toolbar and the map. If you resize your window the map gets refreshed and that gap will disappear and the tooltip shows correct.
http://www.nabble.com/file/p14432821/Clipboard.jpg
So it has to be a JavaScript problem in the AJAX viewer when the viewer is initialised I suppose.
Gunter
View this message in context:
http://www.nabble.com/Trusted-Sites-tp14401044s16610p14432821.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
